Old 08-12-2011, 11:28 PM   #1
Turbobitt
Drives: 2010 2SS
Has anyone broke driveshaft bolts ?
I was pulling out aof a parking lot today and heard a clunk and the sound of parts falling out of the back of the car. Thought I drove over something at first. I continued driving and noticed a vibration. When I got home and inspected the rear, I found one of the 3 flange bolts missing with a piece still threaded into the rear flange. I was able to unthread the stub with my fingers. I also drove back(with my other car) and found the rest of the bolt.
Has anyone broke one of these before ? Where can I get a replacement ?
Allan G.
Turbobitt is offline   Reply With Quote
Old 08-12-2011, 11:55 PM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Not here, but wondering if you had done a burnout or rompped it pulling out,maybe to much torque? Was it a used car? if so then they may have done it before, normally these stand up to the abuse one can give, lucky not more damage was done than the bolts breaking.
SamHouseIII is offline   Reply With Quote
Old 08-13-2011, 12:03 AM   #3
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
NO! i hope this doesn't happen!
Old 08-13-2011, 09:50 AM   #4
steeleshark2
steeleshark2's Avatar
Yes, do you search on here.
Old 08-13-2011, 09:51 AM   #5
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
A guy in our club just had this happen a short time ago.
TonyNo is offline   Reply With Quote
Old 08-13-2011, 10:17 AM   #6
Merc
In The Circle
Merc's Avatar
I bent 3 sets of bolts. Then I got smart and changed out the driveshaft to a 3.5" Driveshaft Shop one piece aluminum one. No more worries now.
Old 08-15-2011, 02:05 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
Originally Posted by Turbobitt View Post
I was pulling out of a parking lot today and heard a clunk and the sound of parts falling out of the back of the car. Thought I drove over something at first. I continued driving and noticed a vibration. When I got home and inspected the rear, I found one of the 3 flange bolts missing with a piece still threaded into the rear flange. I was able to unthread the stub with my fingers. I also drove back(with my other car) and found the rest of the bolt.
Allan G.
You should be able to get a full set of these bolts from your dealership. If you need part numbers just message me and I'll do my best to find them for you. I hope that helps.
Jeff Morris, Chevrolet Customer Service
Old 08-15-2011, 04:19 PM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I threw one bolt a few months ago on my 2010 SS. I heard it hit the underside and felt the vibrations through the shifter stick after that. I bought 4 nut/bolt sets from the dealer and installed just 1 set so I have a full set of 3 as spares just in case. So far so good. Don't let anyone "retorque" your drive shaft bolts!
I would advise getting your hands on an old school beam type torque wrench to do the install. These are single use "torque to yield" fasteners. You can watch them come up to final torque values if you use the beam type wrench. Easy to do if you take your time and do it right.
-Mark.
Old 08-16-2011, 07:43 AM   #9
Turbobitt
Drives: 2010 2SS
Thanks for your offer. I did a search last weekend and found the part numbers and ordered them through GM parts direct. I wasn't expecting the dealer to just hand over a new set without having the car. I don't have much confidence in these bolts since it appears to be a common failure. My guess is that this failure is a result of hydrogen embrittlement due to plating or acid cleaning. Was hoping for someone to have a more
permanent solutuon.
http://en.wikipedia.org/wiki/Hydrogen_embrittlement
Allan G.
Old 08-16-2011, 12:11 PM   #10
Luckymex_dallas
Drag Racer
Drives: 2010 2SS/Rs
VERY COMMON ON THESE CARS...I BROKE FRONT AND REAR..DONT LET THE BACK ONES BREAK OR THEY WILL **** UP YOUR SHIELD AND ITS ATTACHED TO YOUR GAS TANK BIG HEADACHE....MIGHT AS WELL BUILD A ONE PIECE DS. WITH YOKE...THIS DESIGN PISSES ME OFF....BUT THE GOOD THING IS LIKE ON A HARD LAUNCH ID RATHER BREAK THESE THEN THE AXLES....
Luckymex_dallas is offline   Reply With Quote
Old 08-16-2011, 12:13 PM   #11
Luckymex_dallas
Drag Racer
Drives: 2010 2SS/Rs
-Mark.
THREADLOCK ..AND A "WISE" HAND TORQUE...YOUR NOT BUILDING AN ENGINE HERE OR INSTALLING STUDS...LOL SORRY MAN IM SURE YOU BELEIVE IN YOUR THEORIES IM NOT TALKING SHIT....BUT GEEZ
Old 08-16-2011, 12:36 PM   #12
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Not a theory - it's in the GM Service Manual.
-Mark.
Old 08-16-2011, 01:15 PM   #13
Drives: GM Vehicles
Glad to see you were able to get everything you need to take care of this yourself Turbobit. Hopefully I'll have some information on this issue soon.
Old 08-16-2011, 02:16 PM   #14
Turbobitt
Drives: 2010 2SS
I actually stopped at the dealer today during my lunch break. The dealer said they would replace the bolts under warranty and also said they would supply me with the bolts and let me do it myself. They just requested the old bolts back to send to GM.
This works good for me. They get the credit for doing the work, and I get a set of bolts. I'll take the ones I ordered and keep them as spares. Just wish there was an updated bolt.
Allan G.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
Now i broke the rear drive shaft bolts and alot of damage. Vinnysrt8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 07-04-2016 10:41 AM
Driveshaft Shop 9inch conversion in LPE650 2010 BADSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 84 09-22-2011 11:48 AM
Driveshaft Bolts Ovenmitt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 04-26-2011 09:48 PM
Problems with Driveshaft after Coil-overs install..PLEASE HELP!! danrc28 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 04-16-2011 05:55 AM
