Caryle Racing
Old 08-13-2011, 11:28 AM   #1
carbon8
Drives: 2010 Camaro SS,2008 Hayabusa
4l80e swap driveshaft length??
Hey guys,
For those of you that have done the 4l80e swap, can you tell me the dimensions of your drive shaft.
- Daniel
carbon8 is offline   Reply With Quote
Old 08-13-2011, 12:08 PM   #2
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Originally Posted by carbon8 View Post
Hey guys,
- Daniel
You can give Chris a call at GForce1320. He has the dimensions for the SST driveshaft with the 4L85E/9 inch combo.
Old 08-13-2011, 12:24 PM   #3
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
alright bruce, now ur pissing me off..lol...been researching the 4l80e and now you have to post something new...have to ask , after searching 4l80e for 2 weeks...what the hell is the diff between the 2??? i do not see much about the 85..other then th 20lbs tq...and i would think that after building the 80e for perf that it is good...is there any config diff that would benefit going 85e?
mikepage0007 is offline   Reply With Quote
Old 08-13-2011, 01:40 PM   #4
carbon8
-4L80 Specs:
440 lb-ft (597 Nm) (MT1) Maximum Engine Torque
885 lb-ft (1200 Nm) Maximum Transmission Torque (output)
4L85 Specs:
460 lb-ft (624 Nm) (MN8) Maximum Engine Torque
From GM Website:
OVERVIEW
The Hydra-Matic 4L80 and 4L85 are close-ratio four-speed automatic transmissions that serve the heavy duty truck market, full-size vans, as well as school buses and motor home chassis. The 4L85 was added as a heavier duty version of the 4L80 for the 2002 model year. The 4L85 has heavy duty components to handle increased torque and horsepower requirements. Those components include 5-pinion output and reaction gearsets. Within these gearset assemblies, the smallest gears are the pinions that revolve around the sun gears. Four-pinion gearsets are sufficient for most applications, but adding a pinion gear to the gearsets allows them to handle higher loads.
Old 08-13-2011, 01:45 PM   #5
carbon8
so if you beef up a 4l80e you should be in the same boat as if you got a 4l85e.(probably better)
Old 08-13-2011, 01:54 PM   #6
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
-4L80 Specs:
4L85 Specs:
From GM Website:
OVERVIEW
only 460ft lbs? is that going to be strong enough for your engine Speedster?
tho I guess when you get finished with the car... you can tell people you have a motorhome transmission in the car to handle its awesomeness
I piss excellence
and fart awesomeness
Old 08-13-2011, 02:30 PM   #7
mikepage0007
Drives: 2010 camaro
that was my thougthts- better
Old 08-13-2011, 03:56 PM   #8
carbon8
Man all these 4l80e swaps and nobody has the dimensions.
- Daniel
Old 08-13-2011, 05:11 PM   #9
speedster
SST...
speedster's Avatar
Once you gut them, the 4L80E/4L85E are as strong as whatever components are put into them. At that point it really doesn't matter which one you start with. Pretty much every component in the SST tranny is considerably stronger than stock. Even the case is reinforced.
Old 08-13-2011, 06:00 PM   #10
CamaroSpike23
Truth Enforcer
did you have the case (and the engine block while we're on the subject) resonant vibrated to relieve internal stresses before it was assembled?
I piss excellence
Old 08-13-2011, 06:53 PM   #11
speedster
SST...
speedster's Avatar
I don't know about the transmission case. I am sure it was at least shot-peened for stress relief. Tom grabbed 3 LSX blocks and sonic tested and relieved each. He then handpicked the final SST block out of the three. It will be good to go.
Old 08-13-2011, 09:33 PM   #12
mikepage0007
Drives: 2010 camaro
I don't know about the transmission case. I am sure it was at least shot-peened for stress relief. Tom grabbed 3 LSX blocks and sonic tested and relieved each. He made handpicked the final SST block out of the three. It will be good to go.
ot, not gonna let you get off that easy..
Old 08-13-2011, 09:50 PM   #13
speedster
SST...
speedster's Avatar
Nice looking setup !!
Good for some bulletproof HP.
Old 08-13-2011, 10:18 PM   #14
CamaroSpike23
Truth Enforcer
noice.
I piss excellence
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
Pushrod length measuring and zero lash? What lifter preload? robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 11-30-2016 03:08 PM
1968 camaro Protouring show car LS swap 4L80E trans $39,900 customshop1 Autos For Sale / Wanted 9 01-23-2013 05:34 PM
Better Handling Tbanks Suspension / Brakes / Chassis 30 12-15-2010 12:50 PM
Hotchkis versus Pfadt Sway Bars Avalnch Suspension / Brakes / Chassis 77 10-08-2010 11:37 AM
