Old 08-13-2011, 08:49 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Driveline/U Joint/Transmision noise.... take a listen.
Ok. Car has been making this noise for a long time now. Even before the cam and trip to Atlanta to the F-Body Gathering. So I got under it to figure it out thinking U Joint.
You guys tell me......
The car drives just fine othe than the slight wheel vibrations. Noise has always been realy quiet, almost hard to hear but getting easier to hear.
Here is the noise inside the car idling on jackstands. Noise speeds up with car speed, NOT engine speed. Noise happens even with the car off and in nuetral like the second video shows as I had my son spin the rear wheels and I got under it.
Old 08-13-2011, 08:59 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Keep your sons fingers away from those wheels!!!!
dont need another "accident"
your square wheels have thrown your driveshaft out of balance is he joking? or y so serious?
I piss excellence
and fart awesomeness
Old 08-13-2011, 09:02 PM   #3
CamaroSpike23
Truth Enforcer
oh, and I hate your Iphone videos
I piss excellence
Old 08-13-2011, 09:07 PM   #4
PQ
Booooosted.
PQ's Avatar
I need to turn the phone. Plus I can put them on youtube in like 30 seconds but the quality sucks. Audio is good though.
So what do you think all that noise is?
Old 08-13-2011, 09:10 PM   #5
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Sounds like "clank-uh, clank-uh, clank-uh" to me.
U-joints get my vote. Just what you need, spend $1,400 for a one-piece carbon fiber drive shaft and your noise will be gone.
Meh
My 5th is offline   Reply With Quote
Old 08-13-2011, 09:27 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
pq, you got the worst luck..lol....at least when you go in the house at night , you got a hot wife to look at to make all this look like trivial stuff..good luck and keep us posted...with that much noise happening , it should be easy to identify once you get up on a lift..
mikepage0007 is offline   Reply With Quote
Old 08-13-2011, 10:09 PM   #7
PQ
Booooosted.
PQ's Avatar
Sounds like it's inside the transmision almost. Like right under the shifter.
I hope so. Dealer maybe?
Old 08-13-2011, 11:33 PM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Is it coming from the pumpkin? Is anything coming in contact with the axels or drivshaft?
9/26/09 Took delivery!
Old 08-14-2011, 12:29 AM   #9
My 5th
My 5th's Avatar
Are the drivehsaft bolts tight? Some have worked loose and fallen out.
Meh
Old 08-14-2011, 12:47 AM   #10
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
That's a tough one... but I'm sure we'll get to the bottom of it in a few days and 15 pages...
Old 08-14-2011, 02:54 AM   #11
PQ
Booooosted.
PQ's Avatar
No. It's from the front. Right at the output shaft area.
They look thight. But I gotta get it on a lift to know for sure.
Here we go again. Be monday before i can get to it though.
Old 08-14-2011, 07:42 AM   #12
CamaroSpike23
Truth Enforcer
maybe you have an output shaft from an M6...
LMAO
I piss excellence
Old 08-14-2011, 09:38 AM   #13
Becustom
ProCharged 600 + RWHP
Becustom's Avatar
Drives: 2SS/RS White/Hugger Orange
Mine made the same noise . Sounded like a trans problem. 6 spd
When i had it on the hoist running in 2nd gear i would have sworn it was the trans.
But,
It was the stock posi it took a shit the next time i went for a drive.
DSS 9" is in there now.
Good luck.
Becustom is offline   Reply With Quote
Old 08-14-2011, 09:55 AM   #14
mikepage0007
Drives: 2010 camaro
yea, i kinda think that it sounds more like a noise the pumpkin would make...def has a hollow sound that resmbles something inside a case hitting...would be simple enough to pop dshaft out and spin tires...
High Pitched Noise firefighterEMT33 5th Gen Camaro SS LS LT General Discussions 15 10-15-2017 07:15 PM
New rattle noise at 45 Mph and above... Edrock Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 51 01-29-2012 01:51 PM
Noise Coming From Shifter, Is Dealer Pulling My Chain? alterbrett Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 08-02-2010 01:46 PM
odd noise form camaro camarogolfguy 5th Gen Camaro SS LS LT General Discussions 21 04-27-2010 07:57 PM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 10:25 AM
