Caryle Racing
Old 08-16-2011, 01:07 PM   #43
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Ok, I must confess... I didn't listen to the vid till now, I assume you think it's coming from the diff? The double-clunk is in rhythm with the 2 driveshaft bolts, maybe a coincidence, probably not.
Don't know about the rattle. Freaky.
Ask one of the custom Driveshaft guys to give a listen.
I'd like to see the inside of the new driveshaft coupler design, wonder if it's similar to a CV joint, if so, it would make sense. If that's the case your driveshaft may be sloppy if you jerk it around.
It's at the tranny. When I listen back at the diff. there is no sound but what is coming from up front. The popping COULD be from the U Joint in the middle. It's harder to pinpoint BUT the rattling is 100% coming from the rear of the tranny area.
Old 08-16-2011, 07:54 PM   #44
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
[QUOTE=PQ;3624517]It's at the tranny. When I listen back at the diff. there is no sound but what is coming from up front. The popping COULD be from the U Joint in the middle. It's harder to pinpoint BUT the rattling is 100% coming from the rear of the tranny area.[/QUOTE
Man I hope you find it and it is an easy fix. Mine is an LS3 and my center splines twisted at the center slip joint, didn't make any noise but was a bitch to get the stocker out of the car. If it is the shaft I used the Drive shaft shop one piece aluminium and have had no problems with it.
tkrupinski is offline   Reply With Quote
Old 08-16-2011, 07:55 PM   #45
PQ
Booooosted.
PQ's Avatar
Man I HOPE it's just the shaft. Or U joint.
Old 08-16-2011, 07:58 PM   #46
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Is there a doctor in the house?
Old 08-16-2011, 08:09 PM   #47
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
It isn't your drive shaft or u-joint.... that loud and obvious of a noise, you would see that drive shft flopping around...... that is in your transmission somewhere....
You don't notice an shifting issues, or lurching? Did this noise happen to start after a burn out out
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 08-16-2011, 08:10 PM   #48
PQ
Booooosted.
PQ's Avatar
I picked up a set and used them. Pretty cool. But I couldn't pinpoint the sound. The driveshaft was moving and the tranny housing just had no sound in it. I'd swear the sound was coming from the driveshaft. I put the needle on the spinning shat but obviously the spinning of the shaft made it useless to hear.
Old 08-16-2011, 08:12 PM   #49
PQ
Booooosted.
PQ's Avatar
Driving is smooth as silk. Never a miss or hicup. Can only hear the noise under the car. I believe I've narrowed the klunking noise to just above my X-Pipe on top of the heat sheild. Isn't there a U Joint up there between the two shafts?
Anyway, I'l have to wait and just have a good shop diagnose it. I don't want to be buying new bolts several times.
Old 08-16-2011, 09:04 PM   #50
steeleshark2
steeleshark2's Avatar
So what is next??
Old 08-16-2011, 09:50 PM   #51
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
pull the shaft and you will find the noise..
mikepage0007 is offline   Reply With Quote
Old 08-16-2011, 10:01 PM   #52
JusticePete
VIR Specialist
We could use a focussed listenting device.
It is old school, but it works. Place the point on the tranny and the rounded end of the handle to your ear. Move back by fixed points until you are out to the wheel hub. The noise we hear in the vid is loud so you will hear it throughout the process, but you should be able to isolate it between just two points where it will be louder.
Old 08-16-2011, 10:20 PM   #53
PQ
Booooosted.
PQ's Avatar
This weekend I'm going to.
Originally Posted by steeleshark2 View Post
So what is next??
Pull the shaft. It's all I can do. I'll know what to do after that.
My dad does that to listen for leaks in plumbing pipes. He's done that forever. LOL
I tried the stethescope all over the tranny where I could get to. I could hear the sound outside the stethescope better. Almost as if it were in the driveshaft it's self.
Old 08-16-2011, 10:27 PM   #54
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Did you turn the stethoscope on? Did you check the batteries?
Old 08-16-2011, 10:27 PM   #55
JusticePete
VIR Specialist
When you listened at the back end of the shaft near the diff was it similar in volume?
Old 08-16-2011, 10:28 PM   #56
JusticePete
VIR Specialist
High Pitched Noise firefighterEMT33 5th Gen Camaro SS LS LT General Discussions 15 10-15-2017 07:15 PM
New rattle noise at 45 Mph and above... Edrock Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 51 01-29-2012 01:51 PM
Noise Coming From Shifter, Is Dealer Pulling My Chain? alterbrett Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 08-02-2010 01:46 PM
odd noise form camaro camarogolfguy 5th Gen Camaro SS LS LT General Discussions 21 04-27-2010 07:57 PM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 10:25 AM
