Cold Air Inductions
Old 08-16-2011, 10:32 PM   #57
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
The mechanics stethoscope batteries can be found with the blinker fluid at AutoZone.
Old 08-16-2011, 10:41 PM   #58
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
My dad does that to listen for leaks in plumbing pipes. He's done that forever.
I fogot to mention what a smart man your father is.
Old 08-16-2011, 10:48 PM   #59
The Stig
knows 2 facts about ducks
The Stig's Avatar
I think it's in aisle 3 next to the water hammers
Click to view my build thread
Old 08-16-2011, 10:51 PM   #60
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
When you listened at the back end of the shaft near the diff was it similar in volume?
No change as far as finding the noise. I could still hear it better outside the stethescope.
My klunk I'm almost certain now is in the center of the two shafts. The rattling still sounds like it's in the driveshaft up front.
Did you turn the stethoscope on? Did you check the batteries?
he's on eof those guys who just has seen it all.
Old 08-17-2011, 06:55 AM   #61
garcmol
garcmol's Avatar
That rattling sounds to me like something just loose and bouncing off the metal housing. Is there any type of an opening in these driveshafts where a little pebble could find it's way in there? Is the driveshaft hollow where that could happen?
Old 08-17-2011, 08:17 AM   #62
Mr Twisty
Mr Twisty's Avatar
2 piece, joint and carrier bearing where you heard racket???
-- Benjamin Franklin
Old 08-17-2011, 08:22 AM   #63
Mr Twisty
Mr Twisty's Avatar
Is that center joint a cv joint?
Old 08-17-2011, 09:51 AM   #64
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
You want to fill us in on this pic? looks like a Mustang to me.
Old 08-17-2011, 10:02 AM   #65
Mr Twisty
Mr Twisty's Avatar
If you can find a pic of the Camaro 2-piece knock yourself out
Old 08-17-2011, 10:26 AM   #66
Never Satisfied
220/221 whatever it takes
Never Satisfied's Avatar
Drives: See sig....
Here's a shot of the driveshaft..
& a close up of the center joint
Brent
2018 JL Wrangler Rubicon 2-door (on order)
2017 Scat Pack Shaker A8
2016 Challenger Hellcat A8
Never Satisfied is offline   Reply With Quote
Old 08-17-2011, 12:37 PM   #67
Mr Twisty
Mr Twisty's Avatar
Thanks for the pics, Never Satisfied
I doubt it's a coincidence the thumping noise is in sync with 2 of the 3 coupler bolts.... hopefully you'll find and e-brake cable or loose plate/shield making all that clanking racket, seems too loud to be internal (trans)
Do the e-brake cables run thru the tunnel? If so, can you see them when you rotate the D/S? Also could put pressure on heat shields while turning, see if the noise changes.
puss-pull-twist the D/S see if there's any play?
Old 08-17-2011, 01:01 PM   #68
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Ok I have to stick around to see what it is.
IOM Black Diamond is offline   Reply With Quote
Old 08-17-2011, 01:42 PM   #69
PQ
Booooosted.
PQ's Avatar
Ok. THIS is where I'd bet the klunk is coming from. Maybe one of those bracket bolts came off or loose? THAT would be a good thing. Well, considering.
No play at all other than ratating play. And that's normal. BUT, I can only grab a small part until I get that heat sheild off. I can say there is no movement at the tranny or at the diff. I need to get ot the center joint and see.
Old 08-17-2011, 02:34 PM   #70
PQ
Booooosted.
PQ's Avatar
This is at the tranny. Regular play but I swear I can duplicate one of the tumbling clicks. Maybe not. Gotta wait to this weekend.
Turn your volume up. What is that last click? Now I'm getting curious. I gotta tear it apart to see.
High Pitched Noise firefighterEMT33 5th Gen Camaro SS LS LT General Discussions 15 10-15-2017 07:15 PM
New rattle noise at 45 Mph and above... Edrock Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 51 01-29-2012 01:51 PM
Noise Coming From Shifter, Is Dealer Pulling My Chain? alterbrett Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 08-02-2010 01:46 PM
odd noise form camaro camarogolfguy 5th Gen Camaro SS LS LT General Discussions 21 04-27-2010 07:57 PM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 10:25 AM
