JDP Motorsports
Old 08-15-2011, 12:51 AM   #1
Beau
Drives: Fast
I don't post here often but I'd like to give you a bit of help.
Sometimes thinking outside of the box is useful.
For all of you who are struggling with FI due to fueling, I have a suggestion to make.
Add port fueling...
There is going to be a lot of conjecture and theories, but from experience with adding port fuel on top of a stock DI vehicle, it works, and works just fine.
Just make sure that you are hitting the back of the valves with your injector. How to do this?
I'd suggest looking into an LY7 Lower intake manifold, it'll likely bolt right up. It'll already have the correct bosses in there, and if the fuel rail doesn't fit with the LLT upper, run the LY7 upper.
Beau is offline   Reply With Quote
Old 08-15-2011, 01:01 AM   #2
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
This could be interesting.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 08-15-2011, 01:26 AM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I'm confused. Arent' they port fueled anyway? You talking about spraying along with FI?
Old 08-15-2011, 02:52 AM   #4
Beau
Drives: Fast
No, the LLT is a DI motor. I'm talking about adding port fueling on top of this. This is the best solution. The LLT already has a 4 lobe cam for the pump (so we can't add another lobe with a custom cam)(im almost 100% positive).
People need to be logging rail pressure though. If you guys are really running out of fuel due to the mechanical limits of the pump a couple of things will happen.
#1 Fuel pressure will drop off.
#2 As RPMs climb the amount of fuel that the pump will support will also climb.
If neither is the case, you're likely running out of pressure or volume in the tank pump, or you're running out of injector (which I don't think is the case)
Old 08-15-2011, 04:13 AM   #5
PQ
Booooosted.
PQ's Avatar
Ok. I get that but most of them would measure rail pressure. And upgrading the fuel pumping system.
So you mean instead of BAP, duel pump, bigger pump etc ....... ???
Are you doing it now?
I had to change my post. I didnt realize you were talking about the LLT. LMAO
Old 08-15-2011, 07:57 AM   #6
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 08-15-2011, 08:01 AM   #7
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Add port fueling...
It is one of the things we are looking at. However, if we can keep it all DI then we can maintain the cooling benefits that comes with it.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 08-15-2011, 12:55 PM   #8
Beau
Drives: Fast
You still retain all of the cooling effects of the DI even though you are adding port fuel, and you can stage the system if you wish as well.
What is your response on my comment about measuring rail pressure? What have you found?
There are many cars that use both today, including the Lexus IS-F.
Save yourself the trouble, and add port fuel on top of it, you'll be just fine. Direct injection works more like port fueling at high RPM's anyways due to the volume and injection duration. It doesn't atomize quite the same as low rpm. You'll notice a lot of DI cars running 14.5 A/F usually up to around 5000 rpm, after that A/F ratio will drop significantly to around normal port fuel levels.
Seriously. Go on ebaymotors, pick up a LY7 Lower intake manifold, Upper intake manifold, and fuel rail. Heck you could even use stock injectors if you want to start - you'll get them for a song. The issue will be in mating up a simple stand-alone for the fuel trigger and injector control. Problems solved.
Old 08-15-2011, 03:08 PM   #9
GretchenGotGrowl
We've seen two things happen with the rail pressure. The first is just like all the others that the tuner has seen...at middle RPMs the fuel pressure drops too low. The second scenario happens when he tries to compenstate for that...we see the overall flow drop to low at the higher RPMs.
Old 08-15-2011, 03:15 PM   #10
PQ
Booooosted.
PQ's Avatar
I know, I know. I was browsing the 'New Post' page and didn't look at what section it was in.
Old 08-15-2011, 04:15 PM   #11
Beau
Drives: Fast
Ok well that settles it then. You're running out of volume on the high pressure pump. They can be modified, check out what the 2.0FSI guys were doing with them.
However I think it's better to run the port fuel on top of it for many many reasons, namely improved upgrade path, and reliability. Even if it complicates things a bit.
Old 08-15-2011, 04:42 PM   #12
GoPaul
H-Town Camaro Club
GoPaul's Avatar
Drives: 2010 Black Camaro 2LT RS M6
subscribed
Best Timeslip: <Time Slip> Latest Dyno (w. Injen only): <Dyno Sheet> Journal: <Here>
GoPaul is offline   Reply With Quote
Old 08-15-2011, 05:50 PM   #13
GretchenGotGrowl
It's okay. You learned something new about the LLT and now that you are thinking about it something may come to you.
Old 08-17-2011, 10:20 AM   #14
bmorecam
Port fueling sound interesting. maybe you should bring this up to tracy and see what his response is gretch. does anyone know how adkin did with their turbo build? I wonder how they got around the fueling issue even if they got around it
Music for the Maiden Voyage? LSxcellent 5th Gen Camaro SS LS LT General Discussions 1088 05-28-2012 12:43 AM
Disable Post Count? WheelmanSS Site Related Announcements / Suggestions / Feedback / Questions 24 07-13-2011 10:22 PM
How 'bout some Camaro Scotty stories! (warning first post long read!) Hawaii_Subs Vendor and Seller review / feedback / experiences 51 09-28-2010 10:45 AM
Hello First Post, looking at getting one next year Rocketright 5th Gen Camaro SS LS LT General Discussions 11 12-11-2009 08:02 AM
