Old 08-15-2011, 12:17 PM   #1
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Vehicle alignment after drop springs... Wtf?
I put a set of eibach pro lowering springs on my ss Wednesday, and aligned my car Saturday... My question is, the alignment shop didn't seem too concerned about Timing the bushings, but they said they did it "for a piece of mind". They may of loosened the bolts, but they didn't bounce it, and said they never have an issue with bushings. Did they do enough?
They also tell me that I need a set of 400 dollar camber crash plates in order to zero out the front camber, which by the read out is off by .3 degrees... Which is enough to have a slight pull to the right. Am I being jerked around? Or are these plates the only way to get my car to drive straight?
Thanks for anybodys help or suggestions
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 08-15-2011, 06:58 PM   #2
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Can anybody offer any advice?
Old 08-15-2011, 07:08 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Is there a particular reason you're looking to go with 0 front camber? Unless you're running extreme negative camber settings it's not camber that eats tires up, it's toe.
Here is a copy of our alignment guide, it should get you started at getting your alignment squared away.
Pfadt Race Engineering Alignment Recommendations.
Old 08-15-2011, 07:13 PM   #4
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I just wanted the most stock setup, with even tire wear. No track racing, this is my dd.
Should I goto a different shop?
Old 08-15-2011, 09:01 PM   #5
JordonMusser
Drives: 2010 Momentum Race Group Camaro GS.
Different shop, that alignment is terrible.
-2006 Z06, Vortech, Stereo, +Goodies
-2006 BMW 325i, Stereo, +Goodies
-Design.Engineering-Motorsport.Defense
-http://www.Mussco.com
-http://www.JordonMusser.com
JordonMusser is offline   Reply With Quote
Old 08-15-2011, 09:13 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
-.3 degrees camber isn't enough to make you pull to the right, nor enough to eat up tires. I second the motion of finding another shop.
Click to view my build thread
Old 08-15-2011, 09:17 PM   #7
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
I have the Eibach springs as well and the dealership had no issues when aligning my car and timing the bushings.
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Old 08-15-2011, 09:23 PM   #8
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Anybody know of any good alignment shops in the dfw area?
Old 08-15-2011, 10:37 PM   #9
JordonMusser
Cyber-
Give us a call!
Old 08-15-2011, 10:43 PM   #10
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Cyber-
Give us a call!
Hi Jordan, thanks for the help... But could you recommend a shop that's a little closer to Arlington? I live in south Mansfield, and that's a bit of a drive for me
Old 08-15-2011, 10:55 PM   #11
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
If you want it done right make the drive. I live in Grand Prairie and I have been to Momentum twice. Most places don't know about 5th gens, and their suspensions. They do.
If you still don't want to make the trip you can try Classic Chevy in Grapevine, but is it were me I would take the drive to Lewisville.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 08-15-2011, 11:06 PM   #12
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
They don't know how to adjust camber on a ZETA chassis. Chevrolet did not incude the camber adjusting screw or the how to. Here is a picture of the camber screw.
Take your Camaro back to the alignment shop with these instructions:
1. Have them find a bolt in the shop that fits in the hole in the knuckle.
2. They loosen the clevis bolts and screw in for positive camber or out to increase negative camber. They can adjust camber through the wheel spokes with the alignment heads in place.
3. Tighten the clevis bolts.
4. Remove the temporary camber bolt or bolts.
Old 08-15-2011, 11:11 PM   #13
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Originally Posted by bkscott View Post
If you want it done right make the drive. I live in Grand Prairie and I have been to Mpmentum twice. Most places don't know about 5th gens, and their suspensions. They do.
Thanks, like you said... If I want it done right...
Thanks justice Pete... But I honestly would like to avoid that alignment shop if possible, they seemed shady to begin with, so I don't want to risk Amy damage to my ride, I'll probably just make the trip to momentum.
Old 08-15-2011, 11:13 PM   #14
JusticePete
That will work!
Raising/Lowering the car Rocky918 Suspension / Brakes / Chassis 28 03-19-2011 12:03 AM
Alignment needed after Ebiach Springs? gm2376 Suspension / Brakes / Chassis 20 12-03-2010 09:13 AM
springs springs springs ron8879 Suspension / Brakes / Chassis 11 05-24-2010 11:00 PM
The wait for Hotchkis Springs is over! Hotchkis Suspension / Chassis / Brakes 10 02-06-2010 10:31 PM
