Caryle Racing
Old 08-15-2011, 02:19 PM   #1
RedVictory
Luv my LS3
RedVictory's Avatar
Drives: Summit White 2010 2SS/RS M6 LS3
Question Finally Upgrading rotors
I just received my Dimpled and slotted rotors (black zinc finish) from brake performance and can't wait to get them installed
However I'm never done brake rotors or pads and am relying on a friend to help install them and I wanted to see what other tools I may need.
There seems to be little information for v6 models. I understand that I need a torx wrench for the bolt that holds the rotor to the hub and possibly a tap to remove the pins from the caliper. Also some people seem to recommend loctite as well for all bolts, is that really necessary?
also what is the best jack point for a floor jack? I searched and found some conflicting information regarding the cross member in the front, obviously in only doing one corner at a time so I don't see the point in lifting the whole front of the car.
Also I do have one last stupid question, how do you replace the rear pads when you need to engage the handbrake so the car does not move. It's a manual transmission.
Ive searched as much as I can and still have these questions
I promise to upload pics if you guys can help me out
Thanks in advance!
RedVictory is offline   Reply With Quote
Old 08-15-2011, 03:20 PM   #2
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
"C" clamp, or a similar style tool to push the pistons back into the caliper, but your friend should know this....use old brake pad to insure the pistons are pushed as a unit.
There seems to be little information for v6 models. I understand that I need a torx wrench for the bolt that holds the rotor to the hub and possibly a tap to remove the pins from the caliper. Also some people seem to recommend loctite as well for all bolts, is that really nessesary? I have NEVER used loctite on my calipers on ANY car, but to each there own.... I wouldn't
also what is the best jack point for a floor jack? I searched and found some conflicting information regarding the cross member in the front, obviously in only doing one corner at a time so I don't see the point in lifting the whole front of the car. You can do one side at a time by putting the jack right on the jack point supplied by GM. I did this with a floor jack when I changed out my rims
Also I do have one last stupid question, how do you replace the rear pads when you need to engage the handbrake so the car does not move. It's a manual transmission. Again, you can do one side at a time by using the jacking points. If you want to do both sides, just put a "block"/wheelchock on both side of the front tires
Hope that helps
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 08-15-2011, 03:25 PM   #3
RedVictory
Luv my LS3
RedVictory's Avatar
Hope that helps
thanks buddy, i really appreciate the help!
Old 08-15-2011, 03:42 PM   #4
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
NO problem
Racing Brake "Open Slot" Rotors Now Available At APEX Motorsports!!! Apex Motorsports Suspension / Chassis / Brakes 51 04-30-2016 04:25 PM
New to the family. Finally got mine! BA RS Camaro Photos | Spyshots | Video | Media Gallery 17 05-03-2011 09:42 PM
RacingBrake Rear Rotors at last! Doc Suspension / Brakes / Chassis 28 12-12-2010 08:47 PM
