Old 08-15-2011, 10:35 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Anyone else's 2nd gear scratch, alot?
hey guys, even when i push the SS alittle hard and shift out of 1st at around 4,500-5,000; 2nd gear still scratches sometimes. is this like this for all SS's, is it the synchronizer that just takes alittle bit to get the motor and transmission the same speed or what?
Cornflakes'Camaro is offline   Reply With Quote
Old 08-15-2011, 10:43 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
there is a TSB for the second gear "notching"
Click to view my build thread
Old 08-16-2011, 07:11 AM   #3
Cornflakes'Camaro
TSB? and what is notching?
Old 08-16-2011, 08:23 AM   #4
The Stig
The Stig's Avatar
I'll see if I can dig up the TSB (technical service bulletin) for you.
Old 08-16-2011, 09:11 AM   #5
The Stig
The Stig's Avatar
Make : CHEVROLET Model : CAMARO Year : 2011
Manufacturer : GENERAL MOTORS LLC
Service Bulletin Number : PI-0320 Date of Bulletin : DEC 01, 2010
NHTSA Item Number : 10037895
Component : POWER TRAIN:MANUAL TRANSMISSION
Summary :
GM: THERE ARE COMPLAINTS OF CERTAIN GEARS NOT WORKING OR NO REVERSE. THERE IS ALSO A POSSIBILITY OF TWO INTERNAL TROUBLE CODES. *RM
Service Bulletin Number : PIP-4317D Date of Bulletin : NOV 01, 2010
NHTSA Item Number : 10037518
Summary :
GM: THERE MAY BE A LEAK FROM THE TRANSMISSION. THE LEAK MAY COME FROM THE MANUAL SHAFT PLUG. *RM
Service Bulletin Number : PIP-4800A Date of Bulletin : SEP 01, 2010
NHTSA Item Number : 10036244
Summary :
CHEVROLET: INTERMITTENT CLUTCH PEDAL LOW OR STICKS TO THE FLOOR. CLUTCH PEDAL STICKS TO THE FLOOR INTERMITTENTLY OR STAYS LOW DURING HARD ACCELERATION FROM A STOP OR DURING A SHIFT. *PE
Old 08-16-2011, 02:45 PM   #6
Cornflakes'Camaro
so what does that mean for me? do i need to have a dealer look at the car and see what's wrong and/or fix it?
Old 08-16-2011, 03:00 PM   #7
The Stig
The Stig's Avatar
Yes, just take her into a dealer and explain what is going on. They should be able to resolve the issue.
Old 08-16-2011, 06:42 PM   #8
Cornflakes'Camaro
your the man steiger. thanks!!
Old 02-06-2012, 07:02 PM   #9
leisure
Drives: camaro
hey! new to the site. was this issue resolved, or did you discover any further info? (are there similiar threads, elsewhere?)
'12 Camaro (w/ hurst) - grinds into 2nd. not a scratch or notching... it flat grinds, as though i am not even touching the clutch. anyone else having this problem?
thank you in advance.
leisure is offline   Reply With Quote
Old 02-06-2012, 09:27 PM   #10
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
http://www.camaro5.com/forums/showth...ght=gear+grind
You're definitely not the only one.... by a long shot.
https://www.google.com/search?source...2.6.3.5-2l13l0
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 02-06-2012, 09:46 PM   #11
10redrocket
Drives: 2SS Camaro LS3
Mine grinds into 2nd gear just a little when its cold.
It goes away as the tranny heats up, been this way
from the beginning.
I remember some changing the oil out for a synthetic,
which corrected this situation.
Just some added info for you.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 02-07-2012, 12:33 AM   #12
leisure
Drives: camaro
Thanks geaux. Rocket. Much appreciated!
As much as i was looking forward to the arrival of my camaro..... this is extremely discouraging.
Old 02-07-2012, 02:15 PM   #13
geaux_tigerss
Just remember, for every car that has a problem there are a great many that don't. Mine grinds a little in the 1-2 shift if the transmission is not warmed up. Once it is hot I can't shift hard enough to make it grind. It's a solid transmission used in vettes, vipers, mustangs, and camaros. Not to mention you have a 100k mile powertrain warranty and the option of a quality rebuild if you choose to mod.
You shouldn't let this issue be the dealbreaker. Or, more importantly, if this is the dealbreaker, then you didn't really want the car that bad in the first place.
2nd Gear Clunk toilets Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 04-06-2012 10:57 PM
My SS Camaro's tranny sounds weird in 1st and 2nd gear. RyanSSaddict V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 03-07-2011 03:08 PM
Will the A6 start off in 2nd gear like the vette??? TomServo 5th Gen Camaro SS LS LT General Discussions 9 04-10-2009 10:41 AM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
