Jason 98 TA
Old 08-16-2011, 02:44 PM   #1
2quick
Drives: none
LSR Performance install 2012 rear suspension on 2010 Camaro
OK since we are always testing we decided to see what it took to put the rear lca, end links and sway bar on a 2010. we pressed out the bushing and put a new /old one in. that was the most difficult part. here are the pictures. sorry about the quality but it is hard to get a SLR up in there lol. we will be going to the track this weekend to test.
2quick is offline   Reply With Quote
Old 08-17-2011, 07:10 AM   #2
2quick
Drives: none
how many would be interested in a kit to upgrade?
Old 09-11-2011, 10:14 PM   #3
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
How much would it cost? You would happen to have the part numbers for the front swaybar stuff would you?
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 09-12-2011, 12:46 AM   #4
Nessal
Drives: Exige, Miata, Ghia
Looks beefier than the current design. How much would an upgrade kit cost?
Nessal is offline   Reply With Quote
Old 09-12-2011, 07:34 AM   #5
2quick
Drives: none
We are still looking into this.
Old 09-12-2011, 08:22 AM   #6
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Does the fe4 have a bigger front bar as well? Revised location/endlinks?
DietCoke is offline   Reply With Quote
Old 09-12-2011, 08:33 AM   #7
nak3dsnake
nak3dsnake's Avatar
The end links have been beefed up. The front bar is the same size, but its a solid bar now instead of a hollow bar.
Old 09-12-2011, 02:33 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Personally, I think this would be better suited if you replaced the control arm with a aftermarket one. I don't care for the thought of drilling my control arms to make this work. Is there any advantage over the stock location?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-13-2011, 11:08 AM   #9
2quick
Drives: none
We used new control arms. We only used new parts straight from the dealer. No drilling was needed. All the new stock 2012 parts bolted right up after we did some bushing changes.
Old 09-13-2011, 11:56 AM   #10
axis
Search Ninja
axis's Avatar
That makes more sense. Is there an advantage to having the sway bar end closer to the wheel or is this just something different to do?
Halltech CF 102 fed
Old 09-13-2011, 03:59 PM   #11
2quick
Drives: none
Oh YES! it really makes a noticeable change. Your moving the mounting point to a spot where it will have a more direct effect. You could use a smaller diameter bar with the new location and achieve the same stiffness or anti roll characteristics. There is more to it but that is the gist of it. We have been working and testing on the 2012 cad info for some time now.
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
