Old 08-28-2011, 06:27 AM   #15
sting808
Drives: 2010 SS RS
Just installed the Whiteline rear cradle bushing this afternoon. Hardest part was pulling in the coil-overs while lowering and raising the cradle so they don't interfere with the lower control arm. Need to do this and concurrently line up the cradle with the chassis. Cutting out the bushings and prying off the lower washers was not too bad.
sting808 is offline   Reply With Quote
Old 08-28-2011, 07:49 PM   #16
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
Glad to see you got these installed Lionel. The install looks great!
Whiteside Customs is offline   Reply With Quote
Old 08-28-2011, 10:13 PM   #17
sting808
Drives: 2010 SS RS
So far, rear seems more settled and planted under heavy throttle. Great info and EXCELLENT turn around time.
Old 08-28-2011, 11:02 PM   #18
Synner
Drives: not stock
What height jack stands did you need to use to have clearance to bring the whole rear out? Any realignment issues using the motorcycle jack to put it back up there? I'm pretty sure my jack is the same exact one. I didn't drop it for the bush install but eventually will need to for the fuel pump.
Old 08-29-2011, 03:50 AM   #19
sting808
Drives: 2010 SS RS
Took a gamble and it worked. Used HD 6-ton AC-Delco jack stands for rear on 1st tooth with 2x4 wood at unibody. Race Ramp 67" for fronts, 10" lift. Used the Craftsmen pro alum motorcycle jack. Eyeballed and went for it.
All I remember was front cradle washer was ~16" from floor. Couldn't use 3-prong with slide hammer. Mallet taps didn't work, but the pry bar did... Nothing I couldn't smooth out. Rear washer came out with a few mallet taps. Sub frame cleared rear defuser by ~1-2".
Alignment was tricky for one person. Getting the rear guides to line up did take some effort, but only a couple minutes. Pulling in the coilover so they clear the lower control arm stiffening plate on each side, while jacking up and maintaining alignment did require back and forth attention.
Old 08-30-2011, 05:27 PM   #20
Synner
Drives: not stock
Yeah the lower shock bolt was a pain. The 6 tons are basically truck stands so I guess that means I'll need to buy a set; only have 3 tons. Sounds like 20-21" is probably about right for total stand height to have that washer 16" up. The 3 tons only go up to 16 or 17" for most brands.
Old 08-30-2011, 06:22 PM   #21
sting808
Drives: 2010 SS RS
Since I used Race Ramps w/10" height and the jack stand was at the body mount lift points, the rear is angled up. The cut 2x4 wood piece helped raise the car and prevent denting the unibody lift points.
Bought my stands from Checkers/O'reilly, Sears discountinued the 6-ton truck stands. I used my regular jack stands to hold the rear calipers while cradle was out. Pad/caliper fit perfect around the jack stands using shop cloths.
Pretty easy, but time consuming.
Old 08-30-2011, 08:04 PM   #22
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Originally Posted by Whiteside Customs View Post
Dead serious.
Buying straight from the manufacturers has it's advantages.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 08-30-2011, 10:12 PM   #23
Camaro427
Drives: 2010 SS2 Camaro
I have a question with respect to your street one kit. You are including caster washers for the fronts. But I believe these are for normal ZETA platforms and not the Camaro. I also believe the bolts are different a between the normal ZETA and the Camaro.
Camaro427 is offline   Reply With Quote
Old 08-31-2011, 11:44 AM   #24
Whiteside Customs
Originally Posted by brantley847 View Post
Give us a call. We'll be happy to answer any of your questions.
Old 08-31-2011, 11:45 AM   #25
Whiteside Customs
You are correct. The bushings ship with the washers but are not used on the Camaro.
Old 12-14-2011, 04:21 PM   #26
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
could I get a price on the 2.5 and 3 packages? thanks
MileMAN402 is offline   Reply With Quote
Old 12-14-2011, 04:32 PM   #27
Coop
Drives: 2010 Camaro 1SS
Do you guys install? If so how much?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 12-14-2011, 04:48 PM   #28
Whiteside Customs
We sure do! It really depends on which package you choose. What are you using your Camaro for mainly?
Whiteside Customs New Lightweight Wheels Whiteside Customs Wheels and Tires Talk Sponsored by The Tire Rack 85 02-03-2017 08:04 PM
Whiteside Customs Magazine Features Whiteside Customs Camaro Photos | Spyshots | Video | Media Gallery 0 06-23-2011 12:40 PM
THE RED CAMARO--Inside Street Customs seabslew Camaro Photos | Spyshots | Video | Media Gallery 10 04-29-2011 10:13 PM
Whiteside Customs Introduction yyz28 5th Gen Camaro SS LS LT General Discussions 1 10-07-2010 03:37 PM
Super Street Fighter 4 previewed Mindz Off-topic Discussions 18 01-08-2010 05:38 PM
