Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southcentral > Local Marketplace
Old 08-17-2011, 11:29 AM   #1
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Lethal Racing Supercharger Install Specials
We are currently running a sale install special on ECS and Whipple Supercharger Setups. GIve us a call to schedule your install.
ECS Supercharger Setup - $7250.00 Installed & Tuned
East Coast Supercharging has just released their high output Gen V Supercharging system!!! Our base system features the quiet and reliable Paxton Novi 1500 Head Unit, which has proven to to provide more than 750 rwhp on stock LS3s!
This system was designed to be easily installed without removing the nose of the car and provides a dedicated 8 rib supercharging drive system to provide positive belt tracking no matter how much boost youre planning to make.
Our base system is designed to deliver 525 – 570 RWHP on otherwise stock cars, but is expandable with optional head units and blowoff valves capable of more than 1000 RWHP if desired.
Base systems come complete with a polished headunit, bracketry and charge piping, a quiet and reliable bosch blow off valve, a Kenne Bell Boost-A-Pump, 60lb Motron injectors, and a high flow front mounted air to air intercooler system in addition to a dedicated Crank pulley and HD Tensioner assembly. The kits are complete with all necessary hardware, silicone hoses and belts.
System Contents & Features:
  • Kit adds approximately 200hp to otherwise stock vehicles, and the capability to deliver far more on modified cars.
  • Belt driven NOVI 1500 centrifugal supercharger provides unmatched reliability (Vortech YSI upgrade available)
  • Fuel management upgrade includes a Kenne Bell “Boost A Pump” and 60# injectors for safe, reliable operation
  • Self contained oiling for ease of installation and the best possible lubrication and cooling for the supercharger
  • Braided Stainless steel oil drain line
  • Billet aluminum supercharger mounting bracket assembly includes steel double, walled ball bearing idlers, Crank pulley, drive belt and all necessary hardware
  • Crank pin kit and new GM Crank bolt included
  • High-flow, reusable air filter
  • Air inlet restrictor plate integrated into system provides greater low RPM hp & torque while maintaining safe peak RPM boost levels
  • PCV oil separator to eliminate oil vapor from intake
  • ECS Valve Cover Breather
  • Inlet and discharge duct connections utilize heat-resistant silicon sleeves and premium quality stainless steel clamps
  • High-flow Bosch bypass valves provides surge-free compressor operation
  • Large, thermally efficient air to air intercooler
  • System is designed to work with factory cooling system
  • Heavy duty belt tensioner with double walled ball bearing idlers to ensure proper belt tracking and traction
  • Kit comes with new NGK TR-6 spark plugs
  • New 160 degree thermostat to ensure adequate cooling
  • Complete kit fits under stock hood
  • 6061 aluminum ducting
  • Standard kit comes with polished head unit, brackets and ducting
Please note:
These systems will require ECM programming. Tuner kits do not include the fuel pump, fuel injectors, or ECM tuning.
Power output could be much greater with custom tuning and/or on higher octane fuel. Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements.
Whipple Supercharger - $7999 Installed & Tuned
WHIPPLE SUPERCHARGERS EXCLUSIVE FEATURES
  • Only twin-screw that's 50-state emissions legal
  • Front entry W175ax (2.9 liters) Whipple twin-screw supercharger that significantly outflows competitions 1.9L and 2.3L roots-type systems
  • Integrated casting to minimize bolt on pieces, adapters, leaks and flow restrictions
  • Integrated Crusher ™ venturi shaped inlet for maximum airflow capacity and minimal rotor cavitations
  • Integrated Crusher ™ 112mm round inlet outflows smaller 90 and 93mm inlets such as other Eaton based systems
  • Integrated Crusher ™ 112mm round inlet for optional 102mm, 105mm and 112mm TB's that outflow others 110mm
  • Big Mouth Whipple Crusher ™ plastic air inlet for increased velocity and lower inlet temps vs. steel and aluminum tubes
  • Optional Crusher™ 120mm (4.75") air inlet system that outflows competition
  • Integrated design allows for oversized intercooler core compared to other smaller intercooler cores giving Whipple lower air charge temps which allows more boost and timing to be run on pump gas
  • Massive air-to-water aluminum bar-plate intercooler offers more cooling than any other positive displacement system available
  • Whipple Superchargers massive oversized intercooled air-bypass system for industry leading reduction of burst knock and incredible fuel economy, no ridiculous fabbed steel tubes
  • Self-contained oversized oil system for dramatically reduced oil temps in even the most demanding conditions
  • Exclusive 3x5 rotor combo for significant increase in airflow under the curve than less efficient 4x6 rotor combo
  • Zero turn inlet allows for decreased induction losses when compared to rear inlet systems and 180deg bends
  • Center discharge port for better cylinder to cylinder distribution then other twin-screws with cobbled together billet adapters and forward facing discharge
  • Discharge down design allows for less pressure loss which gives more power at lower boost levels
  • Top mount design allows for cooler operation then upside down SC's that conduct heat from engine and are trapped by runners and covers, causing hotter manifold temps and less power per pound of boost
  • More boost at the "hit" than any other twin-screw
  • Flat torque curve for incredible acceleration
  • MSD ™ Fuel pump booster with pre-defined voltage curve for less pump duty cycle then other pump boosters, only supplies increased voltage when needed, others are on/off
  • MSD ™ Fuel pump booster voltage curve can be adjusted by user, no need to purchase "competition" version, already included
  • Oversized heat exchanger for incredible intercooler water temps
  • Optional 4.5 liter supercharger for race applications
  • Fits under factory hood with no modifications
  • No internal modifications required
  • Completed installation looks factory installed, not some cobbled together kit with multiple billet adapters
  • Kits come complete with all necessary parts and hardware for installation
  • Unique oil level sight glass for easy oil level and quality check, no dipstick to bind or misread
  • Plug and play wiring, no cutting or splicing
  • High flow air filter system (50-state legal filter system), coolant reservoir is maintained
  • High flow fuel injectors (63lb/hr)
  • Proven 6-rib belt system with heavy duty spring loaded tensioner and adjustable idler system
  • Stainless steel jack-shaft with unique plastic cover for increased safety
  • OEM quick connect fittings for easy installation
  • Complete kits, Tuner kits and Hot Rod kits are available
  • Available in wrinkle black, polish or any custom color
  • Easily upgradeable with big cold air intakes and bigger throttle bodies (102mm or 112mm)
  • Instant boost at the touch of the throttle
  • 3 minute pulley changes
  • 1 year warranty
Lethal Racing is offline
Old 08-24-2011, 11:17 PM   #2
Lethal Racing
Thanks guys for all the calls and interest. The kit for our shop car is coming in in the next few days. There is also the option of powerdcoating the brackets the same color as your car. Mine is Inferno Orange so I had brackets made in that color. Check em out.
Old 09-19-2011, 11:44 PM   #3
Lethal Racing
3 ECS kits getting installed over the next 3 weeks. Give us a call if you would like to join in the fun!!
Old 09-24-2011, 09:45 PM   #4
BLACK10
BLACK10's Avatar
and there is much fun to be had
BLACK10 is offline
Old 10-18-2011, 11:46 AM   #5
Lethal Racing
Thanks for the Sales!!!
Old 10-24-2011, 11:23 AM   #6
Lethal Racing
Thanks for the sales!!
Old 10-28-2011, 01:39 PM   #7
BLACK10
BLACK10's Avatar
the ECS kit is capable of this!
BLACK10 is offline
Old 11-02-2011, 08:51 PM   #8
Lethal Racing
Thanks for all the sales and support!
Old 11-03-2011, 07:15 PM   #9
Lethal Racing
Thank you for all the sales!
Old 11-04-2011, 11:32 PM   #10
Lethal Racing
Thank you for all the sales and support!
Old 11-06-2011, 12:50 PM   #11
Lethal Racing
Thank you guys for all of the sales!
Old 11-08-2011, 09:59 PM   #12
Lethal Racing
Thanks for all the great sales!
Old 11-09-2011, 07:26 PM   #13
Lethal Racing
Old 11-11-2011, 02:46 PM   #14
Lethal Racing
Thank you for all the support and sales!
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 01:30 PM
**October Supercharger Specials at STILLEN** Team STILLEN Forced Induction 2 10-19-2010 03:02 PM
Cold Weather Blues Prevention Magnacharger Install Specials at Livernois Motorsports! Andy@Livernois Forced Induction 4 12-09-2009 07:53 AM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
