Emblempros
Old 03-25-2009, 01:51 AM   #1
vega$
Dreaming Big!
vega$'s Avatar
Drives: 06 Silverado CC 4x4 5.3L
3.90 or 4.10?
Whos gonna do what?
I'm kind of stuck in between..
3.90 for a daily driver?? or would 4.10 be fine?
vega$ is offline   Reply With Quote
Old 03-25-2009, 02:26 AM   #2
a6pk2go
a6pk2go's Avatar
Drives: ...
Originally Posted by vega$ View Post
Whos gonna do what?
I would personally love to have a 373 gear. Nice road gear with a little get up and go to it.
a6pk2go is offline   Reply With Quote
Old 03-25-2009, 08:11 AM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I too think the 3.73 will be nice mix .. I had 4.10s in my 98 cobra, but that had a different TQ curve and redlined at 7200 ...
Crowley
Crowley is offline   Reply With Quote
Old 03-25-2009, 09:20 AM   #4
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
I'm doing 3.90's but anyone who does 4.10 will not be very inconvenienced. I just do a lot of multi hour driving so I still want a significant overdrive.
Hylton is offline   Reply With Quote
Old 03-25-2009, 11:30 AM   #5
rgrizzard
Drives: Wanting New Camaro
I'm thinking 3.73-3.90 range, I don't wanna lose my top end. Plus 4.10 or more and other work will be required...
rgrizzard is offline   Reply With Quote
Old 03-25-2009, 01:41 PM   #6
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
4.10s. 6 gears on this thing. top end and overdrive will not be compromised
I piss excellence
and fart awesomeness
Old 03-25-2009, 01:51 PM   #7
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
I'd probably sitck with a 3.73 MAYBE a 3.90...4.10, no thanks...
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 03-25-2009, 02:27 PM   #8
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
3.73's would be weak on this car. With as tall as a tire it has, 3.90 should be the minimum, that would put the gearing on par with most stock cars (not a performance gear). 4.10's are OK, but not much better. It has room for much more gear than that. Really, again because of those monster height wheel/tires in the back, this car needs some serious gear. With the stock gearing the car does over 160 in 4th.
THE EVIL TW1N is offline   Reply With Quote
Old 03-25-2009, 02:28 PM   #9
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
You can use this site to look at some information:
3.45s
http://www.car-videos.net/tools/spee...B1=Recalculate
Hmm .. check out what MPH the top of 3rd is here .. bump that rev limiter up a bit and I bet you see a 10th or so off the stock times ... high 12's easy ..
3.90
4.10
Old 03-25-2009, 02:35 PM   #10
THE EVIL TW1N
Banned
3.45s
3.90
4.10
it shouldn't need bumping of the rev limiter at the track. There is enough room in 3rd to finish the 1/4 without shifting into 4th. 3rd should be good enough for ~114 mph based on some other calculators.
Old 03-25-2009, 02:56 PM   #11
Hylton
Hylton's Avatar
3.45s
3.90
4.10
I can see Evils point using your calculator. The car will only be running at 1900 rpm at 60mph with 4.56 gears!
Old 03-25-2009, 02:57 PM   #12
Vash
Drives: 00 Blazer
Keep it stock....
Old 03-25-2009, 02:59 PM   #13
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Originally Posted by Vash View Post
Keep it stock....
Blasphemy !!!
Crowley
Old 03-25-2009, 03:01 PM   #14
Hylton
Hylton's Avatar
Blasphemy !!!
Crowley
+1 - Got to get deeeeeeeeeeeeeeeep into the 12's....
