Old 08-17-2011, 09:26 PM   #1
EM1/SS
Drives: 11 2SS/RS M6 vert
Question on plug on M6
I changed the fluid on my M6 transmission last weekend. there's a torq's plug on the drivers side near the front. I started to loosen it and heard it sucking in so I tightened back up. Can anyone tell me what it's for? And do I need to do anything now that I disturbed it.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 08-17-2011, 09:35 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I know on the T56 there are Torx 40 bolts that hold the internals in line. As long as you didn't pull it all the way out your fine. Even then you would have to try to shift it with the bolt out to try and move something.
SUX2BU is offline   Reply With Quote
Old 08-18-2011, 10:14 AM   #3
EM1/SS
It was a 40 size. Thanks for the response.
My last AAC halo question.. Should every other LED be amber, or Amber and white InvaderMoose Cosmetics and Lighting Modification Discussions 2 05-08-2010 07:16 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Quick question about adding amp / sub to base system B_RADiculous Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-23-2010 02:40 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
