Cold Air Inductions
Old 08-18-2011, 12:58 AM   #1
BROMARO909
SO CAL HEAD TURNERS
BROMARO909's Avatar
Drives: 2010 CHEVY BROMARO
H&R sport spring install
Just installed these springs on my 1LT and the front seems to sit higher than the rear. Is this normal? Is there settling time?
SOCAL HEADTURNERS
APPEARANCE MODS: STILLEN FRONT SPLITTER, CUSTOM PAINTED BOWTIE, TINTED FOGLIGHTS, BLACKED OUT RIMS, CUSTOM PAINTED BRAKE CALIPERS, BLACKED OUT KEYHOLE, 35% FRONT 15% REAR WINDOWS, TINTED TAIL LIGHS, BLACKED OUT TRUNK LID. LIGHTING MODS: BFXENON 6K HID KIT, STEALTH TURN SIGNAL BULBS, LED FOG LIGHT BULBS.
INTERIOR MODS: RED LED BULBS IN MAP/TRUNK, FLAT BLACK CLUSTER BEZEL, CUSTOM PAINTED SHIFTER BEZEL
PERFORMANCE MODS: BLASTIN BOBS AXLEBACK EXHAUST SYSTEM, HURST SHORT THROW SHIFTER, H&R SPORT LOWERING SPRINGS
BROMARO909 is offline   Reply With Quote
Old 08-18-2011, 11:17 AM   #2
Nessal
Drives: Exige, Miata, Ghia
Did you time the bushings?
Nessal is offline   Reply With Quote
Old 08-18-2011, 11:34 AM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Spot on!
Step 1. Pull the car up on to a drive uplift.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Grab the subframes or sway bars, and jounce the car up and down a few times.
Step 4.
Tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Old 08-18-2011, 12:12 PM   #4
BROMARO909
SO CAL HEAD TURNERS
BROMARO909's Avatar
I'll try that. Thanks
SOCAL HEADTURNERS
Old 08-19-2011, 02:06 AM   #5
BROMARO909
SO CAL HEAD TURNERS
BROMARO909's Avatar
What exactly does this do?
SOCAL HEADTURNERS
Old 08-19-2011, 10:51 AM   #6
JusticePete
The rubber bushes in your control arms do not rotate in the arms. They twist. The resistance or load in that twist motion adds to spring rate. When the bush is relaxed, set to the current ride height there is no load. It is at rest with an even resistance when the arm moves up and down. Timing the bushes resets the bush to relaxed in relation to the new ride height. This will allow the coils to show their true height and also improve suspension function.
Old 08-19-2011, 06:13 PM   #7
JusticePete
Old 08-19-2011, 07:57 PM   #8
BROMARO909
SO CAL HEAD TURNERS
BROMARO909's Avatar
Oh ok that makes alot of sense. Thanks! I'm gonna try that this weekend
SOCAL HEADTURNERS
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
RK sport rear diffuser install issues full of days Cosmetics and Lighting Modification Discussions 3 04-09-2013 09:35 PM
Springs & Sway Bar Deals: Eibach, B&G, H&R (Wholesale) MJM Distributing Suspension / Chassis / Brakes 78 03-13-2013 07:32 AM
Hows the Ride ? H&R sport on 22s GreenMonster Suspension / Brakes / Chassis 2 01-23-2011 10:03 PM
Camaro does the Nurburgring test track in 8:20 2sharp 5th Gen Camaro SS LS LT General Discussions 45 07-23-2008 04:17 PM
