Jason 98 TA
Old 08-18-2011, 02:34 AM   #1
Shades
Shades's Avatar
Drives: 2011 Silver Camaro 1SS/RS
Finding garage open???
The last 3 days we keep finding the garage door wide open and nobody opened it. Two nights ago apparently it stayed open all night. Tonight I was going in and out of the garage for an hour using my chop saw and the garage was closed and my wife never left the living room....then she goes out to the garage to do laundry and its wide open again. Is somebody trying to steal my Camaro? 3 days ago the bolt from the garage door opener arm to the door itself came off....i was pressing the button and nothing happened....came into the garage and found the bolt fell out and the arm was moving back and fourth when you press the button not attached to the garage door anymore. I just put the bolt back in and it worked again....but ever since we keep finding the garage open. Whats going on?
Shades is offline   Reply With Quote
Old 08-18-2011, 02:38 AM   #2
Kycamaross
RED JEWEL inthe BLUEGRASS
Kycamaross's Avatar
Drives: 2010 RJT 2SS/RS, 01 S-10 Xtreme
Ummmm you might want to call:
Kycamaross is offline   Reply With Quote
Old 08-18-2011, 02:40 AM   #3
AGENT-006
AKA 'Mr. 006'
AGENT-006's Avatar
Drives: 2010 CGM Camaro
AGENT-006 is offline   Reply With Quote
Old 08-18-2011, 02:40 AM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
if someone wanted to steal your camaro, i think it wouldve been gone by now However maybe its just the garage door opener needs to replaced. I sure hope its not someone trying to steal your car
CAMARO
Old 08-18-2011, 02:49 AM   #5
Blacc Mamba
SoCal HT5
Blacc Mamba's Avatar
Drives: 2010 Camaro
Paranormal activity!!
Blacc Mamba is offline   Reply With Quote
Old 08-18-2011, 02:52 AM   #6
cactuseater
Drives: .
Something going on with the door itself.....had it going on at another house I owned and it freaked me out. Adjustments on the motor got this worked out. If in doubt, give a buzz to the door guy and have them take a look at it for ya.
cactuseater is offline   Reply With Quote
Old 08-18-2011, 03:05 AM   #7
v6
v6's Avatar
Drives: 2012 45th 2LT RS
Set up a f**kin camera man!
v6 is offline   Reply With Quote
Old 08-18-2011, 03:11 AM   #8
MY2012RS
MY2012RS's Avatar
Drives: 2012 1LT
I agree with v6 get a camera going ASAP
MY2012RS is offline   Reply With Quote
Old 08-18-2011, 04:35 AM   #9
DJ UNKNOWN
DJ UNKNOWN's Avatar
Drives: 2011 Red Jewel RS
Then we'll have a paranormal activity 4 movie
DJ UNKNOWN is offline   Reply With Quote
Old 08-18-2011, 04:51 AM   #10
SS_Los
SS_Los's Avatar
Drives: 2011 CGM 1SS L99
Maybe your camaro is a transformer and it's sneaking out for a joyride?
SS_Los is offline   Reply With Quote
Old 08-18-2011, 07:32 AM   #11
Brett64D
Brett64D's Avatar
Drives: 2010 2SS/RS A6 LS3
You might have a neighbor with a new garage door opener that is on the same code as yours. That won't explain the arm bolt "falling off" but might be why it's open. Try disconnecting the arm from the opener when you put the car to bed for the night (to disable the auto opener) and manually lock the door from the inside. If it still happens, get a camera and a 12 gauge :-)
Brett64D is offline   Reply With Quote
Old 08-18-2011, 07:43 AM   #12
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
Originally Posted by Brett64D View Post
You might have a neighbor with a new garage door opener that is on the same code as yours. :-)
this was my guess.....as I have seen this happen before......in fact there was a case of some theives in my towm where they were trooling neighborhoods with a garage door remote going up and down streets till they found a house that it wrked on....then would come back later and rob them. Thats why most garage door opener makers have have gone to ROLLING CODE openers.
Old 08-18-2011, 07:56 AM   #13
Xello
Xello's Avatar
Drives: 2010 CGM 2SS/RS
Change the code switch settings within the door motor and then your entry pin. That should help.
Xello is offline   Reply With Quote
Old 08-18-2011, 08:15 AM   #14
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Do you watch it until its all the way down and stopped? Sometimes, when you have the downward travel adjusted too long, it will tap the concrete and (thinking it has hit an obstacle) reverse and go all the way back open. I have Craftsman chain-drive openers and they occasionally get out of adjustment and this happens...
To check, just open and close it several times and see if it reverses or if there is a thud when it hits the concrete floor.
$300 worth of grocceries and cleaned out my garage fer the Vert. SUX2BU Camaro Photos | Spyshots | Video | Media Gallery 15 03-24-2011 12:01 AM
Open Test & Tune at Zmaxx Dragway 3/19/2011 Blade USA - Southeast 0 03-18-2011 10:59 AM
ZMAX Open Test & Tune 3-19-2011 unccescape USA - Southeast 0 03-17-2011 09:53 PM
My garage floor DIY epoxy project - lots of details and PICS (long) PFYC General Automotive + Other Cars Discussion 19 12-07-2010 03:34 PM
