SDPC
Old 08-18-2011, 12:19 PM   #1
SS>GT
SS>GT's Avatar
Drives: 2010 Camaro SS
break in period for richmond 4.11's?
i got my 4.11's installed on friday and am picking up my beast today. Problem is the dealership lost my paperwork that came with the gears after they installed them, so nowi dont know what my break in period is. does anyone know what is reccomended?
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black.
GO TEAM LS3
SS>GT is offline   Reply With Quote
Old 08-18-2011, 12:25 PM   #2
Russell James
Russell James's Avatar
Drives: '15 1LE
Couple of short distant easy drives. Let it cool off between drives.
All the gear sets I've bought over the years, the instructions are to drive them easy. keep the first couple of drives short, no heavy throttle, cool off. Repeat.
After a couple hundred miles, I'd change the lube, then have at it full power at will.
From Richmond's web site:
BREAK IN
A new ring and pinion installation, especially a high numeric ratio with new bearings, can cause an excessive heat buildup in the rear end and cause softening of the gear teeth and bearings if a break in is not performed.
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for 30 minutes. Do this 2 to 3 times. Towing vehicles need approximately 200-300 miles of normal street driving before being used for towing.
On circle track race cars make approximately 6 to 8 laps at slow speed, then let cool for 30 minutes. Make 6 to 8 more laps at slow speed, then 2 to 3 laps at full speed, the let cool again for 30 minutes.
Drag cars need only an initial run-in since they are driven short distances and heat is not normally a problem with proper lube and backlash allowance.
NOTE: If after the above break in is performed, overheating of the rear end is suspected, repeat the final portion of the break in procedures.
Old 08-18-2011, 12:31 PM   #3
SS>GT
SS>GT's Avatar
BREAK IN
Man, I went with synthetic oil in the dif..is the oil change necessary after break in? And so i basically need to just drive 10 miles and pull over for 30 min 3 times and its broken in?
2010 camaro 2ss LS3
GO TEAM LS3
Old 08-18-2011, 02:27 PM   #4
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I would suggest changing the oil after break in. You will have metal shavings produced during breakin. And yes, I would follow their break in suggestions.
Old 08-18-2011, 02:33 PM   #5
SS>GT
SS>GT's Avatar
well that was a waste of 100$ for synthetic oil lol. i will say though, the ride home was very quiet, couldnt hear any whining at all. only complaint i have is i wish they could adjust the speedo. it seems to be about 6-7 mph off.
2010 camaro 2ss LS3
GO TEAM LS3
Old 08-18-2011, 02:35 PM   #6
Russell James
Drives: '15 1LE
Yes, I would do that for the first day. That will give them a couple of easy heat cycles. Then I would still take it easy for the first couple hundred miles, easy to moderate load. Then change the lube, then harder use/ WOT whenever you want.
New gears and especially clutch type diffs shed a lot of material. It will be a good idea to change it after a few hundred miles.
Not a waste of synthetic, they should always have synthetic in there. Even just for the break-in that will be dumped soon.
Why $100. It's only 1 qt. 1 qt of Royal Purple Max Gear lube with LS additive already in it is < $20.
Old 08-18-2011, 05:04 PM   #7
king pin
king pin's Avatar
Drives: 2011 Camero 2SS RS Conv
Dealer did the work?? what kind of$$$ to do?
king pin is offline   Reply With Quote
Old 08-18-2011, 05:50 PM   #8
steeleshark2
steeleshark2's Avatar
Breakin periods maybe 20 miles at a time. Then cool down for at least a couple hours. After that, be easy on the gears, stay below 4k rpm. I did 500 miles on my gears then chaged the oil and then had fun!!
Old 08-18-2011, 06:36 PM   #9
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Speedo will be off by a percentage. The faster you go, the more off it will be. You have to adjust it in the computer's tune.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 08-18-2011, 07:22 PM   #10
flyby
Drives: 2010 Silver SS
500 miles of mostly stop and go and very little if any highway constant speed miles
flyby is offline   Reply With Quote
Old 08-19-2011, 01:26 PM   #11
curts11
Drives: 2011 ss rs
What dealer was it? I'm looking to get a set installed.
curts11 is offline   Reply With Quote
Break In Period?!?!?! SimC33 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 87 07-07-2012 05:27 PM
When to do proformance upgrades...during breakin or post break in?? iwanttogofastNY Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 06-20-2009 10:38 PM
Break In boricat Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 05-01-2009 01:51 PM
Proposed Bill to give New car buyers tax break GothamCamaro General Automotive + Other Cars Discussion 63 01-22-2009 01:48 PM
break-in period camarofanatic Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-12-2009 10:22 PM
