Old 08-18-2011, 10:00 PM   #1
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
6L80E Tranny failure
So I just had a TCI Streetfighter TC put in and it was coming off the rack to get tuned. The tuner started tuning it and for some reason after shifting into 2 the car would start to shift 3rd, pop into neutral and then shift back into 2nd. Kept doing it for 2 hours. As of now its still at the shop and a transmission expert is coming out to take a look. It seems there is not enough pressure or something.
Hopefully the dealer will cover it through warranty. This is the first time anything has been worked on as far as transmissions go.
If not, I'm gonna have to pay to get the tranny rebuilt.
Anyone else have problems shifting in the A6?
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein
tsears is offline   Reply With Quote
Old 08-18-2011, 10:04 PM   #2
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
The first thing they look at before any major work is your flash count....
KnightRiderSS is offline   Reply With Quote
Old 08-18-2011, 10:24 PM   #3
turboss
turboss's Avatar
Drives: 2010 camaro ss turbo
That's exactly what happened when my tranny broke and I had a broken planetary gear . I had to use tap shift to get home cause 1 -3 rd worked fine I was at 800 rwhp at time so I saw that coming .
turboss is offline   Reply With Quote
Old 08-18-2011, 10:33 PM   #4
tsears
tsears's Avatar
Was it covered under warranty?
Old 08-18-2011, 10:37 PM   #5
tsears
tsears's Avatar
Its been flashed... a couple of times.
Old 08-18-2011, 10:43 PM   #6
KnightRiderSS
Voodoo Medicine Man
Originally Posted by tsears View Post
  1. Its been flashed... a couple of times.
  1. Then your Gm rep won't
approve any major work
Old 08-18-2011, 10:48 PM   #7
Supercharged SS
Drives: 2010 Camaro
I've seen an '10 Camaro have trouble with those converters this year. The first two he got weren't balanced properly. First one happened at the track and blew fluid all over the place on the second pass. The third converter was finally gd. For how long.....stay tuned.
Old 08-18-2011, 10:53 PM   #8
tsears
tsears's Avatar
I got the TCI for free. I have the FTI new in the box. Trying to sell it.
Old 08-18-2011, 10:55 PM   #9
turboss
turboss's Avatar
No warranty car had a converter in it but then I sent the tranny to circle d they did a awesome job when they rebuilt it. Glenn walked me through the shop and showed me what they did to help prevent from breaking again I recommend them if you want to beef your tranny up.
Old 08-18-2011, 10:56 PM   #10
tsears
tsears's Avatar
Damn... I guess I'll be re-building the tranny then. Wasn't expecting to pay that much.
Old 08-18-2011, 10:58 PM   #11
tsears
tsears's Avatar
I'm at about 430rwhp. I wonder if I put the stock TC in and take it to the dealer they will warranty it??
Old 08-18-2011, 11:10 PM   #12
turboss
turboss's Avatar
Im not sure they might its worth a try I just use broken stuff as a reason to put something better but hopefully the dealer will warranty it.
Old 08-18-2011, 11:32 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
What were the shift times set to? If they are too low it can overlap and be in 2 gears at once. I almost messed up with this too. Since I have researched a ton on these transmissions and they are a lot different tuning wise than a 4 speed.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 08-18-2011, 11:35 PM   #14
tsears
tsears's Avatar
They loaded the stock tune in. Still didn't work.
we added some extra protection from the FL heat for my A6 tranny (pics inside) bumblebeecamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 38 12-29-2012 01:11 AM
Camaro team's response to concern about Transmission Output Shaft Failure Mr. Wyndham Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 389 07-09-2011 12:09 PM
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 09:25 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 10:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 02:28 AM
