Solo Performance
Old 08-19-2011, 09:17 AM   #1
mike@thepowdercoater.com
Drives: 2005 Corvette
cadillac cts-v conversion
I know its a popular upgrade, but be advised that when swapping the rears out for cadillac rears, the balance tubes should be moved to the opposite side of the cadillac caliper before installation.
On the camaro caliper, the crossover tube is on the side with the smaller piston. Because the caliper sits on the leading edge of the rotor on the cadillac, rather than the trailing edge like the camaro, the crossover tube is on the side with the larger piston.
The reason for the difference is pad wear and taper. The leading edge wears faster and generates more heat, so to compensate for it, perfomance caliper manufacturers put smaller pistons on the leading edge.
Fronts are oriented the same on both cars, so if doing a front only upgrade there is no issue.
Just some friendly advice from your local powdercoater.
mike@thepowdercoater.com is offline   Reply With Quote
Old 08-19-2011, 09:32 AM   #2
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
That is a great tip. We did flip them on our install, but I do not think we made it as clear as you did.
Old 08-19-2011, 09:37 AM   #3
JusticePete
Your original post has been quoted in Pedders brake thread. Again, thanks you.
Old 08-19-2011, 09:37 AM   #4
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
I was under the impression that the rear calipers were the same besides the color. So no real reason to swap them.
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 08-19-2011, 11:19 AM   #5
Synner
Drives: 2011 2SS/RS M6
They look a bit different and are a different color but yes they have the same braking power. Some people just want them matched front/rear.
Old 08-20-2011, 08:08 AM   #6
No problem. I've learned more about brake systems since I started specializing in powdercoating them six years ago than I ever thought possible.
Old 08-21-2011, 11:50 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Install
What all is involved with installing the Caddy brakes on the rear beside changing the Calipers (new rotors an mounts)?????????
Old 08-22-2011, 04:10 PM   #8
JusticePete
The rear would retain the use of the Camaro rear rotor. You do need to change the tube that connect both halves of the caliper, there is some triming of the dust shield (I suggest using a small grinder) and that brings us to the caliper bolts. They are listed as single use bolts. Many DIYs and GM shops reuse the bolts. That is against the Chevy manual, but if you do, please at leasy use some LocTite.
Mike, check your PM box
Old 08-22-2011, 08:14 PM   #9
what he said!
2008 Cadillac CTS KILLER74Z28 General Automotive + Other Cars Discussion 12 05-08-2016 07:35 PM
Driven: 2010 Cadillac CTS-V TAG UR IT General Automotive + Other Cars Discussion 33 07-07-2010 06:27 PM
GM Reveals 2011 Cadillac CTS Coupe! FenwickHockey65 General Automotive + Other Cars Discussion 47 05-20-2010 11:18 PM
GM Reveals 2011 Cadillac CTS-V Sport Wagon FenwickHockey65 General Automotive + Other Cars Discussion 20 03-29-2010 01:03 PM
CADILLAC IS BACK... Scotsman General Automotive + Other Cars Discussion 17 06-01-2008 12:36 AM
