Old 08-19-2011, 02:38 PM   #1
grocerygetter
instigator
grocerygetter's Avatar
2012 vs 2010ss
I have a good friend that knows his cars pretty well...jumping in and out of an M3 bmw while test driving he noticed how much different the 2012 was than a used 2010 on the lot. He said he thought the '12 car may have handled a little better than the '10 but he said the biggest difference was the attitude of the suspension. The 2012 seemed more composed.
This was test driving down around the Houston area.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-19-2011, 02:40 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Good observation on his part. The 2012 models have some suspension updates.
Old 08-19-2011, 03:39 PM   #3
Group-A Wheels
Drives: Camaro SS
The 2012 cars did get some chasis/suspension tweaks which would have helped.
But, it would also be interesting to know what kind of miles were on the 2010 car...
Group-A Wheels is offline   Reply With Quote
Old 08-19-2011, 06:21 PM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Chevrolet has made a number of refinements to the 5th Gen. Some are running manufacturing changes that you can see. i.e. more rubber in the sub-frame bushes. They have improved the damper map making it a bit more aggressive especially on the bound side. The relocation of the rear sway bar and a slight increase in diameter create a substantial change in sway bar bias. These and other changes do make the 12 a better car.
Having said that, an all out full build suspension on a 2010 compared to a full build all out out 2012 would be a virtual dead heat.
Old 08-19-2011, 09:14 PM   #5
Mark1SS
Drives: 2012 1SS Delivered!
How does the 2012 ride over broken pavement, bumps, & stuff compare with the 2010?
Mark1SS is offline   Reply With Quote
Old 08-19-2011, 10:14 PM   #6
JusticePete
VIR Specialist
I would describe it as more composed with a bit more road feel.
Old 08-19-2011, 10:50 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
One goes ThuMp thUmp ........ ThuMp thUmp .........ThuMp thUmp ......... ThuMp thUmp
The other goes ThOmp thump .......... ThOmp thump ..........ThOmp thump ..........ThOmp thump ..........
Old 08-19-2011, 10:52 PM   #8
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
Toyaholic is offline   Reply With Quote
Old 08-20-2011, 12:25 AM   #9
Mark1SS
Does that mean it doesn't ride like my Lexus LS?
Old 08-20-2011, 12:27 AM   #10
JusticePete
VIR Specialist
Old 08-20-2011, 01:03 AM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Rides just like it until you start moving.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-20-2011, 12:18 PM   #12
Mark1SS
That's close enough!
2012 Hot Rod Power tour IROCanSS USA - Great Lakes 91 06-28-2012 12:47 PM
45th Anniversary Edition 2012 Camaro and New 3.6L LFX V6 Engine FenwickHockey65 5th Gen Camaro SS LS LT General Discussions 647 03-04-2012 02:18 PM
The New 2012 GT-R is OMFG amazing. Mr CLuTcH General Automotive + Other Cars Discussion 80 02-28-2011 11:55 PM
