Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 08-20-2011, 04:58 AM   #1
25thanniversary
25thanniversary's Avatar
Drives: 92 Camaro Convt RS,2011 Camaro RS
a/c problem on my 3rd gen
i have had this problem for quite some time were my car overheats only when the a/c is on. it will start to overheat and i turn off the a/c and it goes back to normal. i checked everything from fluid changed the thermostat a couple of times and nothing still does it. don't know if it's the fan or the relay switch i only have one fan instead of two fans. any previous or current 3rd gen owners have or had this problem. i really miss the cold air my 3rd gen throws out and with this texas heat i need it.
oh forgot to mention it's all stock 305 v8.
TEAM LLT
1992 Camaro Rs Convertible
2011 Camaro 1lt Rs
25thanniversary is offline   Reply With Quote
Old 08-20-2011, 06:35 AM   #2
coolman
Guest
Do you mean the car only has one fan or that only one fan is running? Mine has two electric fans but the second one rarely comes on ,but it does when the ac is running. Also, it could be that the condenser coil and/or the radiator is dirty. Did you ever hose them out? They can look clean from the outside but be very dirty in between the cores.
coolman is offline   Reply With Quote
Old 08-20-2011, 09:53 PM   #3
Camaroirocz
BadMeanIROCZ
Camaroirocz's Avatar
Drives: IROC-Z28 Camaro
Do yourself a favor and get rid of the AC. You will have less hassles, spend less money and won't really miss it that much. You're in Texas but I've driven in high heat/humidity in not just where I'm at now but in Georgia and just bring the windows down and hook up an electric fan and chill to the tunes!
Camaro IROC-Z28 350 L98; Not stock.
Camaroirocz is offline   Reply With Quote
Old 08-21-2011, 12:51 PM   #4
25thanniversary
Yea it only has one big fan and when it goes on it goes on really slowly. Radiator was changend a while back and it would still do it. How would I hose out the condenser so I can try that?
TEAM LLT
2011 Camaro 1lt Rs
Old 02-12-2012, 03:13 AM   #5
Third-Gen
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060
try taking the fan out, hooking it up directly to a battery, and see if it spins faster. The single fans only have one speed, so its either on or off. If it spins faster out of the car, you have an electrical issue. Check the wiring going to the fan. Ive seen a few fan relays go out. When the fan normally kicks on you should be able to hear it inside the car with the windows down. If you have a bign enough amp meter I can tell you what a normal one pulls, I have my old one in the rafters in the garage. Lemme know if that helps!
Third-Gen is offline   Reply With Quote
Old 02-12-2012, 03:17 AM   #6
Third-Gen
Olson Kustom Works
this might help if it gets crazy!!
Parting out my 3rd gen and have alot of stuff. FASTRNL 3rd Generation Camaros 26 07-25-2011 02:02 PM
My thoughts on the 5th Gen...from a 9 year 4th Gen owner TAG UR IT 5th Gen Camaro SS LS LT General Discussions 75 07-19-2011 10:30 PM
another 3rd gen for me? Shadow-phoenix 3rd Generation Camaros 14 07-11-2011 06:19 AM
Z28 and the 5th Gen Refresh. thePill Camaro Z/28 Forum - Z/28 Specific Topics 250 05-25-2011 07:57 PM
Lookin to buy a 3rd gen... NicksVSix 3rd Generation Camaros 12 04-12-2011 05:31 PM
