BORLA
Old 08-20-2011, 01:07 PM   #1
WhereIsMyDog
WhereIsMyDog's Avatar
Drives: 2011 2LT RS M6
Low Sound Quality IPOD Input To Head Unit
The quality from the iPOD is low (compares to the low quality of XM).
I enjoy the text on the head unit; however the quality sucks. Can't adjust output level on iPOD when connected to the 30-pin connector.
When I have it playing thru BlueTooth quality is much better; however, I loose the head unit display (just shows iPHONE connected). Output level to the head unit is adjustable from iPOD. This is my preferred method since the music quality is way more important to me then the display.
It acts as if the input level from the iPOD is very low when connected via the 30-pin connection.
Dos anyone have any tips on increasing this level so I can enjoy the best of both worlds and have better quality and head unit display.
Thanks
I do have the BA speaker upgrade (last car rattled after new system installed and did not want that this go around so I am hoping I can get this corrected without having to take apart anything and/or new head unit which I may just have to do).
WhereIsMyDog is offline   Reply With Quote
Old 08-20-2011, 06:12 PM   #2
HomerBY
Drives: Camaro 2LT 2011
Yes, i noticed that quality is not that good too.
I've got a lame question
How do u play music thru Bluetooth?
HomerBY is offline   Reply With Quote
Old 08-20-2011, 08:13 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
What iPod do you have?
What are your equalizer settings for XM vs USB mode?
What version of PDIM do you have?
While in USB mode, press and hold the Menu button till you see the hardware/software versions on the radio display.
Old 08-21-2011, 01:20 AM   #4
WhereIsMyDog
Both the hardware and software version show DB for the software/hardware version.
EQ settings same for both inputs, tried adjusting bass and mid to compensate but then it overpowers the sound and makes it worse. Bass 3 Mid -2 Treble 4 is about my norm for the good inputs.
The same mp3 when burned to a cd sounds way better when played on the unit. Bluetooth second best, hardwired third.
Tried with an iPhone 4, iPOD classic (2 of the classics).
Old 08-21-2011, 01:30 AM   #5
WhereIsMyDog
when in aux mode select the config button - one of the options is for bluetooth - pair the device and select the gomusic now from the device. This is off the top of my head, I will verify it when I go back out to the car and adjust if needed.
Old 08-21-2011, 06:10 AM   #6
HomerBY
Thanks!
input level, ipod, poor, sound quality
USB port The_Stache Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 09-20-2009 02:44 PM
Sound Quality Through USB & Ipod BryanB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 19 08-12-2009 04:31 PM
Sound Quality with Various Audio Options marcus147 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 07-14-2009 12:53 AM
