AAC Style
Old 08-21-2011, 05:41 PM   #1
Dasein
Dasein's Avatar
Drives: 2011 CGM 1LT
Inconsistency in time needed between shifts... normal?
Hey all
I'm wondering if this is normal... Generally when I start from a stop and I'm ready to shift into 2nd, I need to slip the clutch quite a bit while waiting for the RPM's from 1st to drop to the optimal zone to let the clutch out to enter 2nd. Other times, though, they fall so damn fast that even if I slam it into second and let the clutch out pretty fast, I still get under the RPM's I need to be at and the synchros need to pull the RPM's back up. I get used to each case after 1-2 shifts, but I hate having to switch between slipping a lot and granny shifting into second and shifting really fast... Is this normal or what could the problem be?!
Dasein is offline   Reply With Quote
Old 08-21-2011, 09:29 PM   #2
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by Dasein View Post
Hey all
First off, you shouldn't slip the clutch to bring rpm's down. It will wear out much faster. The 1st and 2nd gear ratios are pretty far apart. How many rpm's are you at before you shift into 2nd? You may not be revving high enough before you shift.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 08-22-2011, 04:46 AM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I found clutch in at 2200 and clutch release at 1800 worked just about perfect every time...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 08-22-2011, 09:19 PM   #4
Dasein
Dasein's Avatar
I shift at about 2500 and I need to re-engage at about 1500-1600. It's a pretty steep drop, so I keep the clutch fully in until it gets to about 1700 then I start to let it out. The RPM's sometimes drop so slowly that I sometimes wait 2 seconds before getting into 2nd. If I shift at 2200, it needs to re-engage at like... 1200-1300 (don't remember exactly). Definitely not 1800 Just seems like I need to keep the clutch in too long before shifting. But other times the RPMs come down so fast I can't shift fast enough. I don't get it! Maybe after it warms up it takes a lot less time to shift 1-2?
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
Help Needed, How much shimmy is normal? Bradnsandy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 06-30-2010 05:03 PM
Help Needed, How much shimmy is normal? Bradnsandy Suspension / Brakes / Chassis 1 03-06-2010 01:07 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
The Next Time You Get Pulled Over..... billjames Off-topic Discussions 44 10-25-2009 09:26 PM
