Solo Performance
Old 08-24-2011, 01:46 AM   #15
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
I ran 18/16 today, and unless you are on a really bad road it still feels like the stock ride. I may crank it up to 20 just to see how it feels.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 08-24-2011, 09:04 AM   #16
caverman
caverman's Avatar
Drives: '69 SS Convertible
Man.....I'm wanting these more and more every day. Especially hearing from the OP how they seem to take out the bounciness of the factory suspension. I always felt that even factory it had more bounce than I really liked and adding drop springs increased it just a little.
I also have mixed Mfg springs and sway bars which now the Mfg's are saying to try to stick to the same Mfg of these so you get match spring rates. I'm assuming going over to coilovers will eliminate this issue as well since you can adjust it to your liking.
I actually might be able to swing these sooner than I thought. I might be able to work it out to get them by the end of next month. Saving up a little to go ahead and have Whiteside do the install instead of DIY this time. I even have the wife kinda on board by showing her these threads on how they are making it ride as good if not better than the factory setup yet we can get real aggressive when we do take the car to the occassion AutoX event.
Keep posting up your settings and reviews when you change them so I have an idea on what settings to try once I do get them.
Thanks guys....
Build Journal
Old 08-28-2011, 05:08 PM   #17
AutoAgenda
AutoAgenda's Avatar
Drives: 69 Camaro, 02 Escalade, 67 Eleanor
Originally Posted by Nessal View Post
Just an update. I spent an hour and a half today and redid the entire front end from complete disassembly to setting the height. The car now tracks perfectly straight. Easy as pie especially having done it once. My fiance didn't know that I installed a new suspension into the car. At 15/15 she didn't mention the car riding firmer or not. So I changed it to 20/20 to get it a bit more firm. We just got back from Round Table Pizza not too long ago with this new setting and she still doesn't seem to know. Not a bad thing in my book!
Today I took a turn a little too fast and the rear end stepped out a little bit but quickly recovered. Felt as if I had a super thick swaybar in the rear or something!
AutoAgenda is offline   Reply With Quote
Old 09-06-2011, 10:56 PM   #18
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
So doing this for the first time solo will take 6 to 8 hours?
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-06-2011, 11:51 PM   #19
Nessal
Drives: Exige, Miata, Ghia
Come to think of it now, I honestly feel that I can do it in 2.5 hours with my buddy. The fronts are cake. The rears I must have taken on and off 4 times now. The rear is the one that is a kind of a pain. Now I drilled the rear so I no longer have to remove them to adjust the damper.
Nessal is offline   Reply With Quote
Old 09-06-2011, 11:56 PM   #20
Rogan
No Pain No Gain
Rogan's Avatar
Come to think of it now, I honestly feel that I can do it in 2.5 hours with my buddy. The fronts are cake. The rears I must have taken on and off 4 times now. The rear is the one that is a kind of a pain. Now I drilled the rear so I no longer have to remove them to adjust the height.
Is an extra hand that vital? Can this be done solo without too many headaches?
Old 09-07-2011, 12:37 AM   #21
Nessal
For me I thought it was priceless especially when it comes to lining up the bolts to put everything back in. But yes, you can do it yourself. Wish I was closer. I wouldn't mind giving you a hand with the install.
Old 09-11-2011, 12:43 PM   #22
AutoAgenda
AutoAgenda's Avatar
Old 09-12-2011, 11:29 AM   #23
yyz28
yyz28's Avatar
Drives: 2000 Sebring Silver Z28
If you're going to do it yourself, on the ground using jackstands/floorjacks, I would make sure you have a second pair of hands. Honestly, we usually put two people on this job at the shop. One person can do it, but having the other set of hands really helps at certain points of the install.
GOOD LUCK!
yyz28 is offline   Reply With Quote
Old 09-12-2011, 12:29 PM   #24
Rogan
No Pain No Gain
Rogan's Avatar
GOOD LUCK!
Ok thanks. I got the fronts on. Think I'm going to get a 2nd pair of hands for the rears.
Old 09-18-2011, 12:48 AM   #25
AutoAgenda
AutoAgenda's Avatar
+1 A second pair of hands is quite convenient!
Let us know if you encounter any issues, done installs of these BC Racing Coilovers on the G8, GTO and now Camaro. All with great reviews!
Old 09-18-2011, 05:23 AM   #26
Rogan
No Pain No Gain
Rogan's Avatar
They are on - but thanks.
Old 09-21-2011, 12:15 AM   #27
AutoAgenda
AutoAgenda's Avatar
Looks amazing! Nice work!
Old 10-09-2011, 09:06 PM   #28
Ozzie RS
Ozzie RS's Avatar
Drives: '11 Camaro RS 2LT
Nessal thanks for the nice post. I just ordered a set from Auto Agenda and this post will be a huge help, hell it already has. I'm going out tomorrow and getting a 15mm ratcheting wrench, lol.
By the way I ordered the ER series of BC coil overs that just became available for the Camaro last week from my understanding. I'll post after the install.
Ozzie RS is offline   Reply With Quote
BC Racing Coilovers 2010 Camaro Ultimate Performance | Ship Same Day| Best Price GTD! AutoAgenda Suspension / Chassis / Brakes 220 01-04-2016 12:19 AM
BMR Suspension and Megan Racing Install and Review Strokedhog Suspension / Brakes / Chassis 4 06-28-2014 03:47 PM
Bkscott gets his BC Racing BR Series coilovers! Whiteside Customs Suspension / Brakes / Chassis 4 08-20-2011 02:21 PM
pfadt and pedders coilovers bmbbl be Suspension / Brakes / Chassis 47 02-14-2011 04:50 PM
