Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 03-26-2009, 10:10 AM   #1
TURBOSCHILZ
Drives: 81 Camaro Z28, 96 Camaro SS
81 Z28 4 SPEED QUESTION...
Can any of you guys please let me know if you think this will work, I have an 81 Z28 (originally a Borg Warner T10 car), pedals and everything still there, I have a matching 81 shifter with linkage (the lift up reverse style), a 4 speed Saginaw transmission from a 74 Firebird Formula, and a clutch kit, flywheel and remaining hardware from a 73 Z28, will all of this bolt up alright without any problems?...
TURBOSCHILZ is offline   Reply With Quote
Old 03-26-2009, 12:16 PM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
No problems at all! Did it a few times years ago. Your speedo will be wrong though because they use different speedo gears but that is easily corrected.
Hylton is offline   Reply With Quote
Old 03-26-2009, 12:48 PM   #3
TURBOSCHILZ
Sweet, kinda figured so, but just wanted to make sure... Thanks a lot for your help...
Old 03-26-2009, 01:10 PM   #4
TURBOSCHILZ
On that speedo gear note... Do they use the same internal gear and just need the speedo cable gear replaced, or how does that work?... Thanks again...
Possible new option packages changes wanted for '11 '12 model years PYROLYSIS 5th Gen Camaro SS LS LT General Discussions 91 09-15-2010 06:15 PM
1997 camaro z28 6 speed flipsta510fazn 4th Generation Camaros 5 03-21-2008 09:00 AM
Gotta question bout my z28 lm1power Off-topic Discussions 1 09-15-2006 03:58 PM
