Old 08-23-2011, 02:55 AM   #1
Moayyed LS3
Drives: 2010 Camaro LS3
H&R SPRINGS 1.4 F 1.3 R.....
Hello Everyone,
I planning to buy H&R springs, but im afraid that the drop is a lot? What do u think? 1.4 front and 1.3 rear?
What do u think of H&R springs?
Kindly submit your suggestions and Pics of ur camaro's lowered.
Thanks.
Moayyed LS3 is offline   Reply With Quote
Old 08-23-2011, 12:27 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Have not personally felt their ride on the Camaro but the members that have posted about them say they are quite stiff. When you stop and think about it, they have to be considerably stiffer since they are quite close to the bump stops. Also, you might have problems getting a good alignment on the rear unless you buy the aftermarket alignment parts. The OEM adjustment is hit or miss with adjusting that far out. If this is your DD and ride quality is important to you, you might want to look elsewhere. As far as quality, I think they are close to Eibach. Meaing, they are more of a budget spring that doesn't have the quality of Pfadt or Pedders. Pfadt makes a 1.25in drop spring that looks great on the Camaro and the company is second to none. They also have fantastic customer service so you know you're 100% covered if you run into any problems.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-24-2011, 12:58 AM   #3
Nessal
Drives: Exige, Miata, Ghia
I ran H&R sport springs before in my previous car and they are quite stiff. Not that I mind though. I think a 1.4" drop is fine. Some of the experts here say that anything over 1.5" is when you run into issues.
Nessal is offline   Reply With Quote
Old 08-24-2011, 02:21 AM   #4
Moayyed LS3
Thanks alot guys i will think about it.
Old 08-26-2011, 06:52 AM   #5
HzMajesty
HzMajesty's Avatar
Drives: 2010 2SS/RS Blk/Blk
Send a message via MSN to HzMajesty
i have H&R's on mine... yes its stiffer, but the aggressive stance alone is well worth it.
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon)
http://www.cardomain.com/ride/3813191#
HzMajesty is offline   Reply With Quote
Old 08-28-2011, 03:14 AM   #6
Moayyed LS3
So you recommend to install it. I see your car often near Costa riffa.. its looked great. keep it up.
Old 08-30-2011, 11:25 AM   #7
HzMajesty
HzMajesty's Avatar
it depends on what ur looking for... if you want to lower just for looks... then yes this is a great mod... if you want performance, handling AND the look, i would go with coil overs (assuming budget isn't a problem). springs are great for looks, the price isn't too expensive and they are a few hours work to install...
i live in that area... thanks
Old 09-02-2011, 07:48 PM   #8
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I have H@R i thought there was not much of a change. I recommend them.ck sig.Thats with 22's. Looks SWEET!
Old 09-04-2011, 04:22 PM   #9
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
I also have H&R springs, the drop is just enough to get rid of the gap in the wheelwell, it does stiffen it up, but not bad.
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 06:17 PM
Springs & Sway Bar Deals: Eibach, B&G, H&R (Wholesale) MJM Distributing Suspension / Chassis / Brakes 78 03-13-2013 07:32 AM
DON'T BUY H&R Springs..Horrible Customer Service ICEMAN 316 Suspension / Brakes / Chassis 8 10-16-2010 12:30 AM
H&R Sport Lowering Springs IN STOCK NOW!! AJ@ECSMotorsports Suspension / Chassis / Brakes 25 10-13-2010 11:35 AM
H&R Sport Lowering Springs for 2010 SS/V6 Camaro Now Available!! Kris@BMCPerformance Suspension / Chassis / Brakes 19 01-17-2010 07:11 PM
