R1 Concepts
Old 08-23-2011, 05:41 PM   #1
Parapdrapa
Drives: 2010 Camaro
Diff help
So I am going to be installing a set of richmond 4:11 gears and I want to make sure I do everything I can to protect my investment.
I know there are quite a few people who have gone thru this process. I plan to the add JRE BILLET CAPS to help strengthen the housing and reducing flex. From the research I have done it appears that the aluminum house flexes cause loading issues and damaging gears.
My question to those who run their cars hard, is there anything else I should upgrade with in or around the housing to reduce flex? I know there is an aftermarket diff cover, but it appears that that component shoots diff oil out of the vent at hwy speeds.
I plan shortly down the road to upgrade my suspension to reduce wheelhop and plant my power. Right now I am just looking for advice on the diff/ gear replacement. And no I don't want to spend 6 k on a 9inch set up
Thanks
Parapdrapa is offline   Reply With Quote
NC/SC suspension shops - diff bushing help full of days Suspension / Brakes / Chassis 13 07-21-2011 09:58 AM
Jannetty Racing Richmond 4:11 Built Diff complete unit 55Designs Transmission / Driveline 13 03-28-2011 05:05 PM
Rear Diff imstr8upg USA - Northwest / Pacific Northwest 7 01-05-2011 11:33 PM
Rear Diff Oil Change @ 2465 Miles Jarhead Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 33 12-16-2010 04:34 PM
who sells aftermarket rear ends / diff (or diff parts) for the 2010 camaro fastfaster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 102 09-03-2010 09:38 AM
