Emblempros
Old 08-28-2011, 09:11 PM   #1
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
PFADT STAGE 2 KIT
If i install this lowering kit do i need to have a alignment done to my car
tpower is offline   Reply With Quote
Old 08-28-2011, 09:13 PM   #2
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
Any time you remove your struts then you need an alignment. The fact that you are changing the ride height makes it doubly so.
Whiteside Customs is offline   Reply With Quote
Old 08-28-2011, 11:39 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hey Tpower! Yep, anytime you change your ride height, you should have an alignment done. Here is the spec sheet for what we recommend for an alignment.
You may have also came across information about "timing" your control arm bushings when installing a lowering spring package. Timing the bushings when you lower the car is a great idea, but not mandatory. The idea behind it is to rotate the bushings in the arms so that they are settled at your new ride height. The actual change in rotation is VERY minimal and will have little effect on the overall ride of your new springs, but it is in good practice. If you have the time to go through your suspension's control arms to loosen and re-clock them to your new ride height, then we recommend it.
The bushings you want to attend to are -
-the rear upper and lower control arm inside bushings (where they attach to the subframe, the upper will be difficult)
-the tie rod bushings
-the trailing arm bushings
-the front lower control arm bushings
-the front trailing arm bushings
If you need further clarification on anything give us a call or PM us. We are here to help.
Old 08-29-2011, 09:23 AM   #4
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
This image has been resized. Click this bar to view the full image. The original image is sized 1074x1521 and weights
Wow you guys at PFADT make it very easy to decide on which product , everytime I ask a question you reply very timely manner, Thank you I am off to order my stage 2
Old 08-29-2011, 09:25 AM   #5
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
And that is why I am going with them
Indy Bumble Bee is offline   Reply With Quote
Old 08-29-2011, 10:40 AM   #6
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I am ordering the stage 2 kit for sure
Old 08-29-2011, 10:54 AM   #7
PfadtRacing
Our stage 2 package sure does transform the car. Here is an email we received a few days ago with some feedback on our Sway bar and spring package (Stage 2):
Installed the sway bars on my Camaro this morning. WOW!!!! Exactly the change I was looking for. Totally transformed the car into something that is fun to drive. Before the car was sort of thrilling to drive, but not really fun. It just felt too big and heavy. These bars really changed it into a much lighter, much more nimble feeling car. BTW we removed the stock front bar without cutting it or loosening the engine mts. Bit of a chinese puzzle, but definitely doable.
Thanks Clay for the email!
Old 08-29-2011, 10:56 AM   #8
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I am already sold , the customer service from you and your company has been top notch and I have not even ordered the product yet. very impressed
Old 08-29-2011, 04:47 PM   #9
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
PFADT Stage 2 Kit ordered
Old 08-29-2011, 05:14 PM   #10
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
You'll be extremely happy with it!
I have the Pfadt Stage 2 on my personal Camaro, and I love it!
It looks the way it should have looked from the factory, and handles even better than it should have from the factory!
JDP Tech is offline   Reply With Quote
Old 08-29-2011, 06:10 PM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Congrats! The Stage 2 really shapes things up.
My Pfadt stage 2 kit install review madmaxx18 Suspension / Brakes / Chassis 33 08-02-2011 07:51 PM
Pfadt stage 1 suspension kit (houston) turboss USA - Texas 0 03-25-2011 08:36 AM
(1 Only) NEW Kenne Bell 2.8 Camaro Kit $5,999.00!!! (Pics Inside) Total_Perf_Eng Forced Induction 9 12-04-2010 10:20 PM
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! PfadtRacing Suspension / Chassis / Brakes 6 10-21-2010 11:47 AM
2010 Camaro Stock Vs American Racing/Magnaflow Vs Vengeance Stage II Cam Kit..Results Ron@Vengeance Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 01-14-2010 02:00 PM
