08-29-2011, 09:56 AM | #1 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Running without tunnel brace
Pics now included in post #17
UPDATE - ARH has called numerous times today and are working diligently to make sure the exhaust can be used with the brace! They are doing all this and dealing with the aftermath of Irene simultaneously....Thanks ARH I recently installed ARH Lt headers and mated it to a SW retro 3" catback. I did not mate up to the SW systems without some minor fabrication. Anyway, the shop that did the headers said that the tunnel brace was not necessary and some Header/catback manufacturers even state that when running headers to a 3" exhaust that the tunnel brace could not be used without hitting. It runs perfectly and i notice no discernible difference from before. I know it provides lateral support for the tunnel, and the fact that the shape of the tunnel due to physics really benefits from some form of support connecting the open ends of the tunnel together. But really how much is necessary. I know the driveshaft bearing is in this area but connected to the top or apex of the tunnel and i dont see how it helps here. I am not a street racer and can deal with some frame flex but again, i have not noticed any. The problem is the x pipe hangs about an inch below the tunnel. I am going to put the car up on jackstands again and loosen everything up from the headers back and jack up the exhaust at the tunnel brace area and make other adjustments as required to try to get the xpipe up further in the tunnel. I ordered an Elite Engineering brace with an additional 1/4 or so inch of clearance and can re use the dogbone spacers that came with the SW retro exhaust to further get clearance. If this can not be done, what do you think of this. allow the exhaust to rest on the brace and i will fab up a mount or bracket to physically attach the pipes to the brace by welding a bracket to the pipes then running a bolt thru the bracket to the brace and tightening it down with a nut....no vibrations or knocks when going over rough surfaces. I have read other threads about not needing to have the brace in place and i have also read that it is absolutely required..... What is the real consensus as to the necessity of it and how many here are running without the brace, and it you have headers and a 3" exhaust, how did you get it to work. Thanks
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
08-29-2011, 10:36 AM | #2 |
Drives: 2SS/RS CGM CAMARO BEAST Join Date: Jul 2009
I took the position that the brace was there for a reason and will not run without it. It is kind of like when I fly, I let the pilot do his job with no advice from me Maybe naive, but that is how I roll. Now, at least you had a choice, but I had Vengeance racing install my headers in the Spring of 2010, and only learned that they had deleted my brace when I installed my exhaust in Summer 2010. Needless to say I was pissed at having to spend $100 on something that should have been put back on the car by Vengeance.
2010 CGM 2SS/RS; 418 stroker; JE Forged Pistons (offset wrist pin); Forged Crank; upgraded valvetrain; Custom Comp Cams Cam; Kenne Bell 2.8; ID 1000s; Aeromotive Fuel pump with return; ARH Long Tubes; Spec heavy duty clutch; 3" Magnaflow Cat Back; Nick Williams 102 mm Throttle Body; Tune fixed by Dave Steck; 815 HP and 14 mpg
Upcoming-- Disintegrated drivetrain; Divorce if/when my wife catches on to my addiction |
08-29-2011, 10:56 AM | #3 |
Yea, if I was your pilot I would not take to kindly to your advice especially since in the jets i used to fly you would be sitting on my lap!
Anyway, i am gonna crawl under the car once my elite engineering brace comes in and see if i can make it work. If not, i have a shop in town that does custom exhaust full time and i will see what they say. I also have an email into Chevrolet, and requested a response from engineering/design to get the real answer....we'll see, im not holding by breath. I know many of the header manufactures say to not use the brace if using the 3 in exhaust with header combo.
08-29-2011, 12:33 PM | #4 |
Boosted Moderator
Hey Bull,
First and foremost, let me thank you for your past or continuing service to this country... My dad and brother are both retired Air Force, my dad as a crew chief and then Chief Tech Inspector, and my brother as an NDI dude... We referred to it as "no duty involved." on to your question.. This will sound strange and it may not be the case, but I've seen a few cases where the X pipe was installed upside down and this created clearance problems... I'm running three inch pipes and have no clearance problems... Just a thought... I know the tunnel brace looks flimsy, but it is there for a reason... good luck with the search for information...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
08-29-2011, 12:36 PM | #5 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
I used some washers to drop mine down... I think I have 3 3/8" washers on each bolt.
No problems hitting the tunnel brace any more.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
08-29-2011, 01:08 PM | #6 |
I had the washer thing going when i did the install to the stock manifolds. not an issue. The headers are lower than the stock manifolds and the xpipe is a good inch below the tunnel brace. I havent put it on jackstands to check things out, looseness etc but plan on in when my new tunnel brace comes in. I am sure the shop that put in the headers knows better than putting in the x pipe wrong. I will look at that also.
08-29-2011, 01:12 PM | #7 |
Blessed
You might be surprised how many X pipes get installed upside down..
I kinda like the idea of attaching the pipes to the brace...
08-29-2011, 01:15 PM | #8 |
Drives: 89 IROC 350 Join Date: Mar 2009
Goo look in the GM engineer thread. I posted why I have heard it's there. Side impact rigidity, keeps the trans tunnel from collapsing under hard lateral impact.
Yes, I am an engineer No, I don't have a tunnel brace DO NOT ATTACH THE PIPES TO THE BRACE!!! The pipes need freedom to move or you will get one hell of a vibration! Make sure you have 1/4 to 1/2 between the brace and pipes. |
08-29-2011, 01:17 PM | #9 | |
I really think this would work. Run a piece of 1/4 inch flat bar stock across the top of the exhaust with a hold drilled in it. run a long bolt thru it and thru the tunnel brace. Pop on a nut and cinch it down. Voila, no rattling, no issues. surely it is not that simple though.
08-29-2011, 01:20 PM | #10 |
The exhaust was accidentally attached to the brace on our supercharged mustang... Sounded like the car was going to explode. A five minute adjustment to get 1/4" and all was good. Trust me, don't connect them! There is a reason why the exhaust hangers are rubber... It isn't for ease of install
08-29-2011, 01:24 PM | #11 |
...especially if you have an aftermarket cam! Remember, the engine moves... A LOT. The headers are hard mounted to the block and the exhaust has all rigid connections. If you solid mount the exhaust to the tunnel brace, when the engines moves around it's either going to break something of make a horrid sound.
Now on topic... You're likely 100% safe without the brace. Not like the car is going to wrinkle like piece of paper without it if you get into am accident. Like I said, I don't have one. Guess I'm a rebel |
08-29-2011, 01:26 PM | #12 |
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X Join Date: Aug 2011
Yeah, idunno, the engine moves a lot while driving (unless you install some Pfadt engine mounts), and the exhaust moves even more, so hard bolting it to the chassis probably isnt a good idea, and could be very bad for your headers or heads, when the engine is torquing back and forth, and the exhaust is held in place. It would need some sort of flexible bushing or something.
If you do any spirited driving, I'd definitely have the tunnel brace in position. |
08-29-2011, 01:35 PM | #13 |
THANKS Jeremy.
I just called my shop that took my brace and I'm picking one up today!!! I'm doing a "flat out" road course day in a few weeks... Guess I should get it mounted. Plus, all I do is spirited driving!! |
08-29-2011, 01:43 PM | #14 | |
Blessed
When my exhaust was hitting the brace it was enough to trigger the knock sensor..
Similar Threads | ||||
Tunnel brace with more clearance? | VEESIKS | Suspension / Brakes / Chassis | 12 | 07-23-2011 12:28 AM |
BMR Launches New Product - 67-69 F-Body Convertible Tunnel Brace | BMR guy | 1st & 2nd Gen Marketplace | 1 | 05-07-2010 02:19 PM |
Spohn Extreme Duty Tunnel Brace Released | SpohnPerformance | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 10-18-2009 07:43 PM |
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) | BMR Suspension | Suspension / Chassis / Brakes | 30 | 10-12-2009 08:15 AM |
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) | BMR Suspension | Suspension / Chassis / Brakes | 0 | 09-30-2009 02:03 AM |
