Old 08-29-2011, 11:43 AM   #1
Brettscamaro
BrettsCamaro
Drives: Black 2ss Rs
Faded Brembo caliper?
My black brembo caliper on my 2011 2ss has 7200 miles on it and they are faded like a chalk color white? Any suggestions?
Brettscamaro is offline   Reply With Quote
Old 08-29-2011, 12:01 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Clean them.
Old 08-29-2011, 12:10 PM   #3
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I have the same problem and it is not a cleaning issue, Its like they are over heated
tpower is offline   Reply With Quote
Old 08-29-2011, 12:11 PM   #4
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I don't think they start off as black anyway, I think they're gray.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 08-29-2011, 12:14 PM   #5
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Powdercoat! They'll look 100 times better and you won't have to worry with them ever again. Several have done it whether they're Brembo or not.
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 08-29-2011, 12:15 PM   #6
Brettscamaro
BrettsCamaro
I do clean them...It is definitely not a cleaning issue and I don't think an overheating issue either. Because no matter if I drive up the block or down the parkway and jamming the breaks they stay white. The car has 7200 miles on it...
Old 08-29-2011, 12:35 PM   #7
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Brake Caliper Finish Degradation or Staining
If this helps.....
Service Information
Document ID: 2668469
#PI0244A: Brake Caliper Finish Removal, Degradation or Staining from Wheel Cleaning Chemicals - (Jun 3, 2011)
Subject:Brake Caliper Finish Removal, Brake Caliper Finish from Wheel Cleaning Chemicals
Models:2010-2012 Chevrolet Camaro SS
This PI is being revised to add the 2012 model year. Please discard PI0244.
Condition/Concern
Some customers may comment on a degradation of the finish on BremboŽ brake calipers standard on Camaro SS models.
Frequent application of harsh wheel cleaning chemicals may have attacked the finish on the brake caliper. Most wheel cleaning chemicals advise not to let the product come in contact with painted or finished surfaces but customers may not have thought to protect the decorative brake calipers.
Recommendations/Instructions
Important: Acidic wheel cleaners may craze, crack, discolor or remove the finish on the brake calipers. Damage from wheel cleaners is not covered under the vehicle new car warranty. Soap and water applied with a soft brush is usually all that is required to clean the calipers.
The brake calipers on the Camaro SS are black anodized aluminum. This coating provides a durable and attractive, chip resistant finish. Acid based products and harsh detergents should be avoided (see vehicle owners manual). If non-recommended cleaners are used, every attempt should be made to follow the instructions on the label and to assure the calipers are shielded from these cleaners.
The picture below is an example in which wheel cleaner has removed the majority of the finish on the front side of the caliper.
Finish Removed by Wheel Cleaner
Notice: Do not use cleaning solutions that contain hydrofluoric, oxalic and most other acids on any General Motors wheels or brake calipers. These cleaning agents are destructive to various automotive finishes.
In the second photo below, you can see how contact with the wheel cleaner is limited to the face of the caliper. The original finish remains present as you look toward the back side of the caliper.
Brake Caliper With Partial Finish Removal
Further Assistance
Damage from wheel cleaners is not covered under the vehicle new car warranty, and no attempt should be made to correct this condition.
If the customer wishes to apply some type of decorative finish on the brake caliper, most retail auto parts stores sell high temperature automotive brake caliper paint. Caliper paint products by *Dupli-Color are available nationwide. The customer may refer to www.duplicolor.com for additional information and local dealers for these products.
*We believe these sources and their products to be reliable. There may be additional manufacturers of such material. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from these firms or for any such items which may be available from other sources.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 08-29-2011, 08:18 PM   #8
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by MS3DALE View Post
If this helps.....
Service Information
Condition/Concern
Further Assistance
Great post. I barely had to type a response.
Old 08-29-2011, 08:28 PM   #9
BeckyD@JamesMartinChevy
BeckyD@JamesMartinChevy's Avatar
Pete hard at work again
Great job
Don't forget, I honor ALL DISCOUNTS THAT APPLY!
Available Inventory -James-Martin Chevrolet
BeckyD - I Deliver Nationwide!
..only 20 min from Detroit Metro Airport!
BeckyD@JamesMartinDetroit.com
ChevyFleet@aol.com
BeckyD@JamesMartinChevy is offline   Reply With Quote
Old 08-29-2011, 09:40 PM   #10
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
yea if you already have them off...
MARINE1991 is offline   Reply With Quote
Old 08-29-2011, 09:52 PM   #11
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
dupli colour here I come
Old 10-21-2011, 04:42 PM   #12
eric0353
eric0353's Avatar
Drives: 2017 Camaro 2SS
does painting your calipers void your warranty? my dealer doesnt want to paint mine red...
2017 2SS Camaro - M6 - Hyper Blue Metallic - White Pearl Rally Stripes - Khalari Interior - Khalari Knee Pads - NPP - Sunroof -
eric0353 is offline   Reply With Quote
Old 10-21-2011, 05:00 PM   #13
ajp
SHK-TRPR
ajp's Avatar
Drives: Camaro 2016 2SS
That blows, are we expected to reach in and cover the calipers every time we clean the wheels?
Which by the way, is often given how much brake dust these cars produce...
Looks like I will be powdercoating mine soon...
http://www.camaro6.com/forums/picture.php?albumid=1554&pictureid=145486
ajp is offline   Reply With Quote
Old 10-21-2011, 06:08 PM   #14
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
What are you cleaning your wheels with?
From GM's perspective, all of their wheels are clearcoated and can be washed with normal soap and water. There is no need for "wheel cleaner" sprays. If you go aftermarket and get wheels that need special cleaners, then why should GM pay to take care of the damage your cleaner solution did?
Just my thoughts...no reply needed.
rolnslo is offline   Reply With Quote
Pricing on painted brembo caliper covers Reloaded Suspension / Brakes / Chassis 9 07-12-2011 12:47 AM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
Thoughts about the Brembo caliper paint fastball 5th Gen Camaro SS LS LT General Discussions 4 03-18-2009 11:22 AM
