Old 03-27-2009, 12:06 AM   #1
2Muchmark
2Muchmark's Avatar
Drives: 2013 2SS RS 1LE
Send a message via ICQ to 2Muchmark Send a message via MSN to 2Muchmark Send a message via Skype™ to 2Muchmark
No remote start with Manual Transmission?
After reading my order sheet for the 1,000,000th time I realized that the L99 package includes a remote started, but that the LS6 (that I ordered) does not. I assume it is because of the manual transmission? Or is there another reason?
2Muchmark is offline   Reply With Quote
Old 03-27-2009, 12:09 AM   #2
TheCaptain
N7 Spectre
TheCaptain's Avatar
You are correct on the manual, and incorrect on your engine code you ordered. I bet you meant LS3 though!
Way too many insurance problems to deal with having remote start on a stick.
Old 03-27-2009, 12:10 AM   #3
09'Z28
The "Mad Hamster"
09'Z28's Avatar
Drives: '71 Camaro, '90 mx5, '71 2002
First, you got an LS6 in your car? I think you mean LS3.
Second, the manual doesn't have remote start because A) if you accidentally leave the car in gear if will move when started and B) the car doesn't depress the clutch for you so it can't even start i the first place.
Hopefully that made sense
09'Z28 is offline   Reply With Quote
Old 03-27-2009, 07:16 AM   #4
2Muchmark
2Muchmark's Avatar
Yes I meant LS3, sorry about that -
And thanks for the info!
Old 03-27-2009, 07:24 AM   #5
cam2fst4u
cam2fst4u's Avatar
Drives: 08 SS trailblazer,08 Silverado
Send a message via Yahoo to cam2fst4u
yep...no remote start on the manuals.
cam2fst4u is offline   Reply With Quote
Old 03-27-2009, 07:36 AM   #6
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
if you really want it you can get it through a aftermarket alarm system that has it to where it will only start if the car is in nuetral and the parking break is set, that comes with a clutch bypass so thats not a problem. i have done this for a buddy of mine before and it works perfectly
Gentry78 is offline   Reply With Quote
Old 03-27-2009, 07:42 AM   #7
arozar
Drives: 2007 Tahoe
So you have to leave the car in neutral right?? That's just not safe, brakes lose tension, your tranny will not.
Past f-bods
1989 IROC (350/L89)
1995 Trans-AM M6
2001 Trans-Am WS6 M6
http://site.despair.com/governmentmotors/
arozar is offline   Reply With Quote
Old 03-27-2009, 07:43 AM   #8
arozar
Drives: 2007 Tahoe
Of course they can pop out of gear!!
Past f-bods
1989 IROC (350/L89)
1995 Trans-AM M6
Old 03-27-2009, 07:46 AM   #9
Thwick
Drives: 2007 Cobalt SS/SC
I wouldnt recommend it, even if you can get it through the aftermarket. To use it you'll have to leave your car out of gear, relying on the e-brake alone. E-brakes can fail pretty easily if you're on even a slight slope, they arent that strong. I'd rather leave my car in gear without the e-brake than leave it in neutral with the e-brake on.
EDIT: arozar beat me to it.
Thwick is offline   Reply With Quote
Old 03-27-2009, 07:51 AM   #10
Gentry78
HOOK'EM
Gentry78's Avatar
thats true, if you do this you would have to keep up with that.personally if i was going to do this to my car(which i'm considering) i would only use it somewhere like my garage/driveway where its nice and flat or some place like that. if i was to be parking on a hill somewhere i would use common sence and never leave my car parked without it being in gear or without the wheels turned the corresponding way so if anything fails my car wont go rolling down the street.
Old 03-27-2009, 09:07 AM   #11
Baughman
Baughman's Avatar
Drives: Black 2SS/RS
Well if it's something you really want, they make manual aftermarket remote starts. I will probably be looking into this later on
Black/Black, 2SS/RS, Manual, and Polished 20's
VIN# 28396
Baughman is offline   Reply With Quote
Old 03-27-2009, 09:25 AM   #12
Vash
Drives: 00 Blazer
I have seen a few accident threads out on other forums for people that modded in a manual remote start.
My advice is just don't do it.
Old 03-27-2009, 09:27 AM   #13
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
Not to mention, adding an aftermarket remote start will VOID your warranty.
Bad bad bad....
Embalmer is offline   Reply With Quote
Old 03-27-2009, 09:31 AM   #14
Vash
Drives: 00 Blazer
Well if it's automatic it might not void it. If you use an authorized installer. Like a DEI authorized installer. GM has been buying controller stuff from DEI for a while anyway. Because I do advise everyone to add 2 way Alarm pager to your Camaro. Nothing beats it... beeps in house.. they could rip the system out and you still got the ***********ers.
Remote Start Durability kanys 5th Gen Camaro SS LS LT General Discussions 33 03-28-2009 07:43 AM
Remote Start Available for the Manual Tranny? Rodrunner 5th Gen Camaro SS LS LT General Discussions 36 12-30-2008 10:35 AM
Remote Start l008com Camaro Price | Ordering | Tracking | Dealers Discussions 34 11-18-2008 03:19 PM
Manual Transmission Options usmc320 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 04-07-2008 01:20 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 05:11 AM
