SDTW Custom Wheels & Tires
Old 08-30-2011, 12:59 AM   #1
Darkone
Darkone's Avatar
Drives: 2011 Camaro LT/RS SIM
Pedders, LSR, BMR, Pfadt installed!
I got the Pedders EP 1201 full cradle bushings, Pedders Radius rod inserts, LSR chrome moly trailing arms, BMR rear sway bar, and Pfadt end-link mounting brace installed along with the MRT V2, all at one go!
A couple of points,
JucticePete at Pedders is AWESOME to deal with, and offers the best customer service I have ever come across.
If u have access to a lift, it makes installing anything easy. The shop mechanic with my help got the full cradle bushings installed in 1 hour 15 minutes! (Yes I timed it, and this included getting the car up). Tip: Use flame to melt the old bushings, then jack up the rear cradle with a bottle jack after wedging something between the bushing and the car frame, and the bushings get pushed out easy! -Thanks for the advice Rob@Wretched
All those worried about road noise with the cradle bushings, don't be. Honestly couldn't tell ANY difference in road noise at even high speeds. The MRT on the other hand drones a lot above the 2000 rpm range at 80+ mph.
All these mods resulted in a car that handles and feels way better than stock on turns and on a straight line. I'm sure once I get my alignment done it will be even better!
Here's some pics. Sorry for the dirt, its extremely dusty in Oman.
Darkone is offline   Reply With Quote
Old 08-30-2011, 03:28 AM   #2
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
congrats on the mods
HaddadMotorsports is offline   Reply With Quote
Old 08-30-2011, 04:16 AM   #3
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: Black 2SS/RS 14; Jeep 5.7 GC 15
I guess that you were given some extra tips on that date.
Like how can a Camaro SS beat a Nissan GTR .
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 08-30-2011, 09:31 AM   #4
2quick
Drives: none
Great! Glad your enjoying your car.
2quick is offline   Reply With Quote
Old 08-30-2011, 11:29 AM   #5
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Thank you for the kind words. We welcome you to the PEDDERS NATION!
Old 08-31-2011, 09:37 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cool mod' list! You have most Sponsors/Vendors covered, LOL!
Regarding the subframe bush replacement: Did your tech' use the actual bottlejack to push the bush out of the subframe? I got a little lost there... I'm sorry I think I got the wedge-part. I've only noticed others use a sawsall and drill to cut through the voids in the bushes and then hammer them out after dropping the whole rear subframe. It sounds like you left yours in.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-31-2011, 02:18 PM   #7
Synner
Drives: 2011 2SS/RS M6
I left the frame in and used the sawzall method so its possible. Didn't use a drill for anything. Bottle jack was probably easier but both methods are doable.
Old 08-31-2011, 02:37 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
GREAT! Thanks much for the information!!! These are all mods' I'm going to be considering.
Old 08-31-2011, 04:24 PM   #9
JusticePete
The bottle jack will work most of the time. It depends on how fresh the powder coating was when the OE bushes were installed. If the powder coat was on the soft side it acts like a glue to hold the fiber reinforced plastic jacket in place. You can heat the area to soften the powder coat and that will do the trick most of the time. Some times you end up doing it the hard way.
You can use PVC pipe joint, a couple of steel plates, acme threaded rod, washers and nuts with a high torque impact wrench. That is tough for most DIY shops because they don't have sufficient CFM and / or pressure.
Old 09-01-2011, 02:33 PM   #10
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Man you are making things complicated on those poor guys !!
Cant you just put one of these in your package and save our time .
I bet that he can pull your bushes with his lips.
Old 09-01-2011, 03:12 PM   #11
JusticePete
We thought about that, but shipping costs were prohibitive.
Old 09-01-2011, 03:27 PM   #12
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Just put him in a sealed wooden box and put a sticker on the top ( M1 Abrams Tank spare parts ).
Our friends in the militray will spend a couple of coupons to deliver him through their Cargo free of charge .
Old 09-01-2011, 03:33 PM   #13
JusticePete
That is a far better solution that we got from our shipping and receiving department
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices JDP Motorsports Suspension / Chassis / Brakes 115 02-16-2015 08:42 PM
MAJOR PEDDERS EVENT IN iNDIANAPOLIS! SATURDAY, MARCH 20TH. MEET PETE Info@PeddersUSA.com USA - Great Lakes 38 03-22-2010 08:33 PM
BMR CHASSIS BRACE INSTALLED lawdogg149 Suspension / Brakes / Chassis 19 12-14-2009 08:39 AM
