BeckyD @ James Martin Chevy
Old 08-30-2011, 10:41 AM   #1
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Quick ? on rear subframe bushing inserts..
Just got the front washers off the subframe bolts-
its not the back ones that are tougher, are they?
Old 08-30-2011, 10:54 AM   #2
Ventmaster
Ventmaster's Avatar
Doesn't matter, I was taking a short break and the longer I sit here the tired I get so...I'll find out on my own.
And if those subframe bolts were torqued to 74lb/ft at the factory, Ill eat my wrench!!
Old 08-30-2011, 11:25 AM   #3
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Never done the bushing inserts, so I can't help you there, sorry.
We usually replace the whole bushing with solid mounts, as it stiffens everything considerably more, without compromising comfort or noise.
But since you're local, we can help you with about anything else your heart desires!
From looking over their instructions, it seems at that point, both front and rear should be about the same difficulty.
Maybe a little easier since they're a little bigger...
Maybe a little harder since they may be harder to get to...
JDP Tech is offline   Reply With Quote
Old 08-30-2011, 12:11 PM   #4
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
Fronts were definatly harder to get off than the backs for me!
ssmike is online now   Reply With Quote
Old 08-30-2011, 12:27 PM   #5
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Don't blink or you will miss the plate fall off.
This works equally well on the front or rear plates.
Old 08-30-2011, 12:31 PM   #6
Synner
Drives: not stock
Yeah the backs have a bit more room to grab onto. The smaller fronts were a tad tougher. I heated them up first which helped (10-15 seconds with a torch).
Old 08-30-2011, 12:55 PM   #7
Ventmaster
Ventmaster's Avatar
Yep, the fronts were much tougher-thank God!
I was afraid I'd done the "easy" ones first and they kicked my a$$.
Thought the bigger ones might be worse, but fell off in comparison.
Good to go now-can't wait to try them out.
And I don't have any fancy pneumatic jackhammers, or lifts, or anything that might make this easy, JusticePete!
Just a one man operation with jackstands, handtools, and a masochistic streak.
Also a > two and three quarter inch gap between my tire and fender. I'm gonna be needing some drop springs soon! This Pedders stuff IS addicting!
Talk to you soon and thanks for the inserts
Old 08-30-2011, 12:57 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
I used the two hammer approach. Took about 4 good blows of the hammer and they came right off. Rears took 1 good blow.
Use whatever method works best for you and gets them off.
Build Journal
Old 08-30-2011, 01:03 PM   #9
Ventmaster
Ventmaster's Avatar
I had memorized your insert post before starting caverman, but still had a time with the fronts.
And despite using every precaution I could think of, I ended up having to pry a bit to line up my pins as well.
Alls well that end well. By the time I've saved for the next mod, these aches and pains will be gone and I'll be ready for the next challenge!
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
subframe bushings & rear sway bar Larz29 Suspension / Brakes / Chassis 20 01-29-2012 12:43 AM
Pedder's Rear Bushing Inserts JohnZ Suspension / Brakes / Chassis 5 06-22-2011 03:54 PM
VIDEO of New Pfadt Aluminum Rear Subframe Bushings, available now! PfadtRacing Suspension / Brakes / Chassis 39 05-27-2011 04:01 PM
VIDEO of Pfadt testing their NEW rear subframe mounts! PfadtRacing Camaro Photos | Spyshots | Video | Media Gallery 25 03-22-2010 05:11 PM
