Old 08-30-2011, 05:50 PM   #1
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Problem with safety loop touching DSS aluminum Shaft
It only happends during hard cornering to the right. You can see the minor damage in the first pic.
Lucky for me my brother built me a custom one 1/8 of and inch bigger (2nd pic).
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 08-30-2011, 10:20 PM   #2
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
You need some subframe connecters!
Kewl that your brother hooked you up with a bigger loop.
Squintz Palladoris is offline   Reply With Quote
Old 08-31-2011, 12:00 AM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Needs stronger engine/diff mounts/cradle. SFCs wont make as big a difference, as the driveshaft position is always relative to the back of the trans (engine), and diff (diff/cradle)
DietCoke is offline   Reply With Quote
Old 08-31-2011, 12:28 AM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
How much larger in diameter is the DSS aluminum shaft compared to the stock shaft?
Old 08-31-2011, 01:03 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
They have options and choices depending on material...
The biggest one on their site shows to be a 3.5" shaft, though I thought I read somewhere they have a 4" option... I could be wrong...
Old 08-31-2011, 02:41 AM   #6
JM10
Se habla espaņol
JM10's Avatar
I already have BMR subframe connectors
I didnt have problems with the OEM shaft, only when I upgraded to an aluminum one along with 3.91 gears from RPM. :(
I also got the pedders diff bushings.
Dont know the OEM size but the aluminum DSS is 3.5
I will try the bigger loop tomorrow, dont know if it will fit since there's not to much room down there...
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 08-31-2011, 10:10 AM   #7
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Let us know how it works for you. We also use a 3.5" diameter aluminum shaft and have not had this issue. The loop was designed fairly tight to the tunnel if I remember correctly but if there is room to widen them for larger driveshafts we may do that on the next production run...
BMR guy is offline   Reply With Quote
Old 08-31-2011, 10:28 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I notice you have a lot of BMR parts, but I haven't noticed if you've gone thought all the bushings in the rear... If so, maybe you need to get solid engine mounts, like the OP already suggested
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-31-2011, 12:44 PM   #9
JusticePete
or sub-frame bushes or reset his engine and transmounts or tighten them or find a broken mount or get a new loop if he has a 4" shaft.
Old 08-31-2011, 05:15 PM   #10
Squintz Palladoris
Or a Chromoly Cage.
J/K let us know what you find to be the cause/solution.
Old 08-31-2011, 11:08 PM   #11
JM10
Se habla espaņol
JM10's Avatar
Update:
After some minor modifications to the "bigger" loop now everything is
Looks like there's more room to the sides of the loop than to the top. Mechanic had to shorten the new loop because it was blocking the shifter.
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 08-31-2011, 11:23 PM   #12
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
That loop isn't legal where it's positioned, and would also be ineffective in the case of a shaft break... lol.
Your loop is literally around the joint, it must be completely physically behind the joint, no more then 6 inches back. One of the issues using this style loop with that style of coupler-adapter driveshaft
In place of a crossmember, in the vicinity of the front universal joint, all cars in competition using open driveshafts, must have a retainer loop 360-degrees of enclosure, 1/4-inch (6.35 mm) minimum thickness and 2-inches (5.1 cm) wide, or 7/8-inch (22.2 mm) x .065-inch (1.65 mm) welded steel tubing, securely mounted and located within "6-inches" (15.2 cm) of the front universal joint f or support of the driveshaft in event of U-joint failure.
Old 08-31-2011, 11:43 PM   #13
JM10
Se habla espaņol
JM10's Avatar
Weird since I didnt change the location of the holes holding the loop. That DSS shaft better hold up or
I had no problems passing inspection during camarofest2
Maybe bmr could explain the location of the loop.
JM
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 09-01-2011, 12:48 AM   #14
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
No, but you changed the type of shaft. With a stock shaft, the loop is behind the joint. With the DSS shaft, it is not.
Pirate Manufacturing Aluminum Side Vent problem FroSSt Cosmetics and Lighting Modification Discussions 1 08-19-2011 01:16 AM
Our first DSS 9 Inch Conversion and Detailed review. 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 04-15-2011 10:24 AM
DSS Aluminum Driveshaft, New Design complete, brand New. 55Designs Transmission / Driveline 6 04-04-2011 07:23 PM
Hendrix-Engineering aluminum drive shaft in testing Hendrix-Engineering V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 24 01-26-2010 06:09 PM
