Emblempros
Old 08-30-2011, 05:10 PM   #1
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Whipple Pulley Issues
Curious what pulleys you guys are using to get what boost. I know this is a very imperfect science but I am sure the answer is here or close at least.
My car has LTs, Rotofab and a blower cam. On the 3.875" pulley it only produced a whisker over 7.5 psi. I want to see at least 10 if not 12 psi....what size pulleys are you running to get what boost on a similar combo? We have two more pulleys on order....just curious what you are seeing on your combo on what size pulley etc.
Any thoughts.......also interested to hear what you are running for timing in your tune as well.
Thanks.
HufferSS is offline   Reply With Quote
Old 08-30-2011, 05:20 PM   #2
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Keep in mind the cam changes your boost level compared to the stock cam..Dont get hung up on a boost number i would stop at 600rwhp with a stock motor
Hendrix-Engineering is offline   Reply With Quote
Old 08-30-2011, 05:29 PM   #3
jrpxxii
jrpxxii's Avatar
Also remember that long tubes will take 2psi out of it as well.
Old 08-30-2011, 05:36 PM   #4
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Nah.
Old 08-30-2011, 10:53 PM   #5
shines
Thanks.
I have a 3.65" pulley and get only 8lbs, but that's on a 419 stroker with a blower cam, ported heads, and LT's.
shines is offline   Reply With Quote
Old 08-31-2011, 12:25 AM   #6
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
We have the 3.5" pulley on order....so should be about right.
Numerous issues with my 2011 SS Runin11z Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 07-29-2011 04:02 PM
TVS2300 set-up question(s) TinyToasta Forced Induction - V8 51 03-14-2011 01:40 PM
Cog Pulley for magnachager Paul4137 Forced Induction 1 01-06-2011 10:51 PM
Smaller blower pulley or bigger crank pulley? B-rad Forced Induction - V8 14 11-14-2010 12:09 AM
