Old 08-30-2011, 09:03 PM   #1
CalEditor@pcmcalibrators
Drives: Camaro
Aftermarket Shift Levers Gear Hop Out Or Clash
GM take on Aftermarket Shift Levers
With Tremac manual transmission RPO M10, MG9, MM6, ME2, MH3, MZ6
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2699000&from=bcpi#ss1-2699000">Condition/Concern:
Some customers may comment on gear clash or shifter does not stay into selected gear (hop out). Customer may a comment on excessive shift effort. Also may have concerns of excessive noise from the shifter or shifter area. Upon inspection the vehicle may have an aftermarket shift lever installed.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2699000&from=bcpi#ss2-2699000">Recommendation/Instructions:
For RWD manual transmission vehicles, the shift stop positions are designed internal to the transmission, neither GM or Tremec endorse using aftermarket shifters that incorporate external stops (See photo below) as they can cause several issues with the transmission including - hop out, incomplete gear engagement, clash, etc. The use of the external stops is not endorsed and any internal transmission damage associated with their use would not be a warrantable item.
Hop Out: As the shift is being made the synchronizer sleeve is moved from a disengaged state and the internal teeth of the sleeve match up with the external teeth on the blocking ring. When pressure is applied to the blocking ring by the movement of the sleeve the blocking ring will, through friction surfaces, stop the speed gear allowing the sleeve to engage the clutching teeth on the speed gear. The internal transmission shift rods and levers have a designed point at which the synchronizer sleeve stops. This point is where the sleeve is fully engaged with the speed gear. Having the synchronizer sleeve fully engaged to the speed gear means less chance of the transmission hopping out of gear.
High shift effort: Excessive shift effort can be caused by shift levers that claim to "shorten the throw" or reduce the amount of travel at the driver's hand or arm. To achieve this, the lever is usually shorter or has altered the pivot point of the shift lever. When this is done there is less mechanical advantage to the driver and therefore increases effort to move the shift lever. Also if the pivot point is changed that can change the amount that the synchronizer sleeve is moved not allowing for a positive engagement to the speed gear
Gear Clash: GM Powertrain engineering and our transmission suppliers have taken proper steps to ensure that the speed gear is slowed down at the proper rate. Any attempts to force the speed gear to slow down any faster can cause the friction material or clutching teeth to be damaged causing the gear clash complaint.
CalEditor@pcmcalibrators is offline   Reply With Quote
Old 09-03-2011, 12:26 AM   #2
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Does GM identify any specific "culprits" by name? Where is the photo they mention in the text?
Meh
My 5th is offline   Reply With Quote
Old 09-07-2011, 11:03 AM   #3
Wink2010
Wink2010's Avatar
Drives: 2010 2SS/RS LS3
Aftermarket Shifters
I sure wish this thread continued. I too want to know which shifters have external stops and which don't. I can't see where the aftermarket shifters that are basically shortening the throw by lowering the stick height could be a problem.
2010 JEGS Sweepstakes Winner! JBA Axle Back, HalltechYellow Jacket, Adaptive Performance Skip Shift, Elite Catch Can, BMR Trailing Arms, Clutch Fluid Reservoir
Wink2010 is offline   Reply With Quote
Old 09-07-2011, 11:41 AM   #4
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
Hell I've had hop out with the stock shifter. But if I feel too much resistance I usually don't try to then slam it into gear. I really need to get the Transmission and Differential fluid changed. I hear that really helps a lot.
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Halltech Aluminum Gear Shift Knob for the 6 speed? Halltech Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 11-14-2009 09:03 PM
Does any 6 speed owners see a need for a gear indicator? OHIOSS 5th Gen Camaro SS LS LT General Discussions 98 10-13-2009 09:36 PM
Gear Shift nimnels Cosmetics and Lighting Modification Discussions 1 04-07-2009 07:44 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
