Gen5DIY
Old 03-27-2009, 05:28 PM   #1
The Boat
His seafaringness
The Boat's Avatar
Drives: yugo
Variable Valve Timing
Will gm ever offer variable valve timing on LS engines? If so how much of a power increase could we see?
The Boat is offline   Reply With Quote
Old 03-27-2009, 05:36 PM   #2
69Firebird
69Firebird's Avatar
Drives: 2010 Black 2SS/RS LS3
The L99 is basically an LS3 with AFM and VVT. The VVT is really used to make engines more efficient not for more power. Because the L99 only has 1 Cam it can only change valve timing on exhaust and intake ports at the same time. If we had 4 overhead cams they could phase the exhaust and intake separately and we may see bigger differences, but then we wouldn't be dealing with an LS series engine.
Delivered 8/4/09: Black on Black 2SS/RS, LS3, CGM Stripes, Polished Upgrade
K&N Typhoon Intake, Stainless Works 3" Catback w/ S-Tube Turbo Mufflers
69Firebird is offline   Reply With Quote
Old 03-27-2009, 05:37 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
its possible, its already in use.... L99.
its been in use in the L92 motor as well
what I would like to see (technologically speaking) is a camless motor.
I piss excellence
and fart awesomeness
Old 03-27-2009, 09:02 PM   #4
fierodeletre
Drives: 02 WS6 TA, 88 Fiero Formula
I think they call it variable cam timing though. Same difference, just one shaft, not four like the LLT, or two like the LSJ et cetera. and I agree Spike. I think a camless V8 would be a cool way to leapfrog Ford and the Japanese in tech, totally bypassing the whole OHC thing.
Edit: Oops sorry double post
fierodeletre is offline   Reply With Quote
Old 03-28-2009, 08:11 AM   #5
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
I've spent some time thinking about that in the past. If you could use a solenoid to reliably and acurately open each valve, your ecm could change the whole power of your motor throughout the rpm range on the fly. It could automaticly adjust lift, duration, and overlap at the perfect time to produce maximum power while keeping the idle smooth and your gas mileage high and even keep wheel spin under control. Now as soon as I figure out how to build it I will be the most powerful gear-head in the world BWAHAHAHAHAHA!
Here is a similar idea that seems interesting but I have heard conflicting results. http://www.coatesengine.com/
Robert91RS is offline   Reply With Quote
Old 03-28-2009, 09:44 AM   #6
CamaroSpike23
Truth Enforcer
hell yeah. that coates site... that is some wicked stuff they are working on
I piss excellence
Old 03-28-2009, 11:29 AM   #7
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
Hot Rod Magazine did an article on this back in 2001 I think. I think they put it on a Ford 5.0L and it picked up right at 100 hp and they spun it to over 8,000 RPM. I tried to find the article on-line but couldn't, and I got rid of my old magazines. Interesting stuff though. I have an idea of my own for a camless head. Now I just need a billion or so dollars to get it running!
UsedTaHaveA68 is offline   Reply With Quote
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 04:03 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
So...the L76... Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 51 04-07-2008 01:21 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
VVT on the new Camaro Casull Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 04-01-2007 01:55 PM
