HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 09-03-2011, 12:58 AM   #1
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
No brakes mystery
Lets time line run this down again.
One day my brakes went to shiet, hard pedal with no stopping power unless I lean on them hard. [I do member the rear locking up once]
Folks suggested it was the MC and the fluid in it was nasty.
So while changing the MC,
I warrantee and exchanged my calipers and brake pads as I could.
I also put on a new set of rotors. [drilled and slotted]
No change in operation.
Other suggestion that the nasty fluid in old MC messed up the prop valve.
Prop valve has been changed with no change in brakes.
Last part left was the brake booster, changed it today and no change.
Changed rubber lines today also just incase I had a funny internal blockage that can happen with them.
Still no change.
Have run near a whole gallon of fluid through no problem bleeding them and no change.
Every part of the brake system is "new" all except hard lines, which I have no clue how they could be the problem.
Tossing money and parts at it has gone no where, now what???
2013 5th Gen Firebird on order.
86 Pontiac Firebird [a work in progress]
[68 Firebird hoodscoops, custom notchback[1-3 built]rear mounted tach, inverted wing]
http://www.thirdgen.org/techboard/v6...-all-over.html
"In certain extreme situations, the law is inadequate.
In order to shame its inadequacy, it is necessary to act outside the law.
To pursue... natural justice.
This is not vengeance.
Revenge is not a valid motive, it's an emotional response.
No, not vengeance.
Punishment."
2ndgenz28 is offline   Reply With Quote
Old 09-03-2011, 10:50 AM   #2
macalot
macalot's Avatar
Drives: 1969 + 2015 Z/28s F250 SD
I only know tons about first gens...if it has a vacuum operated MC, check and make sure a vacuum is making it to the MC.
Only other thing I can think of is a metering block in the brake line somewhere that might be plugged.
Good luck!
macalot is offline   Reply With Quote
Old 09-03-2011, 12:17 PM   #3
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
vacuum is fine, will try and suck your finger off.
no metering block for the fronts, they each have their own line off the prop.
only the rears use a single line to the back then splits once back there.
Old 09-03-2011, 01:15 PM   #4
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Had this happen to my 91 rs, turned out to be a piece of clear plastic from the seal of brake fluid can, found by accident after a complete rebuild of master cylinder, i could have swore it was the brake booster. Small piece about the size of paper hole punch. Was on the front side of the cylinder
SamHouseIII is offline   Reply With Quote
Old 09-03-2011, 07:00 PM   #5
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Did you use a reman booster? I went thru 4 of them on my old C10 when revamping its brakes before I got a good one! And tho it is rare, I have replaced a few bad proportioning valves....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 09-04-2011, 01:25 PM   #6
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
That brings up a good point, pretty sure when I got a new MC, they made me reused my old resivor / it didn't come with one. Maybe its fouled in some way.
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
KNS Brakes - Say hello to the FNG! KNS Brakes Sponsor Announcements / Giveaways / Contests 47 01-21-2011 11:18 PM
KNS Brakes - Your Street and Racing Brake Experts KNS Brakes Suspension / Chassis / Brakes 50 01-21-2011 11:00 PM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 08:23 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
