sjm autoprod
Old 03-27-2009, 11:04 PM   #1
Riderover40
Riderover40's Avatar
Drives: 2010 ABM Camaro 2SS LS3 w/RS
LS3 to 500 HP Suggestions pls Economically
So to add 100 ponies without head work: Shouldn't there be G8 LS3 mods available soon ??
1) Exhaust -
2) Headers -
3) Intake -
4) Mild Boost -
5) Free Air induction -
6) Program ECM (tuning)-
7) Maybes like changing pulley sizes -
Roto Fab CAI, Magnacharger MP2300, Kooks HO SS 1-7/8" LT's, Kook's Catted Connectors, Corsa SS Dual Rear Exit Cat-Back for A6 with Lasered Livernois Signature 4" Dual Wall Exit Pipes, Barton Short Throw. 546 RWHP 517 RWT
This Car Rocks !! "Bring It On" GT-500
Riderover40 is offline   Reply With Quote
Old 03-27-2009, 11:15 PM   #2
vladkgb
Drives: 2000 Camaro SS Pewter
My LS1 easy hit 455rwhp (~500hp crank) with nothing but a p1sc procharger @ 5 psi, LT's and borla cat back, and a very good tune. Id say the quickest way to get to 500hp is via procharger, they already have g8 kits, engine bay is similar to camaros:
Id like to do something like this once i get my camaro, i got the kit from my ls1, will justneed some parts to adapt it. But i think its smart to wait it out the first production year to make sure any recalls/bugs are fixed by the warranty.
And of course theres always nitrous.
Edit: notice the weird placement of the air intake from the procharger, good SS have that cowl hood.
vladkgb is offline   Reply With Quote
Old 03-27-2009, 11:26 PM   #3
JJ#48Racing
Drives: 1998 Camaro SS
You're not going to get 500fwhp without doing a cam, unless you go forced induction which is a great way to go, but not economical. Staying NA, you should get 500fwhp with:
Air intake
Long tube headers- I'm not sure if the LS3 likes 1 3/4 inch or 1 7/8 inch better for NA power.
Mid-pipes with high-flow cats
Cat-back exhaust
Moderately aggressive cam with appropriate valve springs
Dyno tune
Heads can stay stock
Your best bet is to go onto a Corvette forum and ask the LS3 vette guys what they're doing.
JJ#48Racing is offline   Reply With Quote
Old 03-28-2009, 02:43 AM   #4
davidj
davidj's Avatar
Drives: .
The GMPP "Hot cam" makes 50hp with no other mods.
davidj is offline   Reply With Quote
Old 03-28-2009, 03:43 AM   #5
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
Yes but won't it void the warranty? I would love to do this but I'm not sure.
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 03-28-2009, 06:32 AM   #6
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Vettes are making 500 RWHP with bolt-ons and cam, they are making ALMOST 400 rwhp stock. I think if you are willing to do the bolt-ons: headers, exhaust, CAI, Pulley, custom cam, Tune...you will exceed where you want to be, if you don't mind a few extra $$ you can throw on the new FAST 102 intake and add an additional 12-20 rwhp.
If you are worried about warranty, then leave it stock. You have to pay to play in this game, its all a gamble. My TBSS just spun a rod bearing, so now I'm having to use alot of my camaro "mod money" to fix it. I'm not gonna "put it back to stock" then take it to the dealer like nothing happened, that's just dishonest. Understand that ANYTIME you start making significiantly more power than stock, things are gonna tear up, and you must be prepared $$ to fix it (especially if you will be depending on the camaro as transportation).
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 03-28-2009, 11:06 AM   #7
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Im going to be supercharging .. after having an 04 cobra at 509rwhp / 520rwtq .. nothing else will cut the mustard .. I'll do magnacharger or something like that for the best low end response (nothing like it) .. I'll be shooting for at least 600 crank HP ..
Crowley
Crowley is offline   Reply With Quote
Old 03-28-2009, 11:28 AM   #8
blackedout010
Drives: on order black 2010 2ss
500hp or 500rwhp?? magnusson is releasing a tvs 2300 application within the next month or so and that with supporting mods. or you could always go cam or heads and cam. i wouldnt waste money on a hot cam theres alota better out their for same or even less cash.
honestly id go (when there availible)
ar or kooks headers
corsa cb
cai
pulley
cam
tune
these will get you 500+rwhp and with addition of some tea ls3 heads and lsxr intake you be at the 550+rwhp range
blackedout010 is offline   Reply With Quote
Old 03-28-2009, 11:40 AM   #9
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
ar or kooks headers
corsa cb
cai
pulley
cam
tune
I don't think you will find it that easy for what you are saying will give you 500 rwhp .. no way you are getting 140hp out of headers, cb, cai, pulley, cam, and tune (at least and not still be a daily driver) ... maybe 500 rwhp w/ heads and cam etc ..
just my 2 cents .. 500 crank you could do I think though ..
Crowley
Old 03-28-2009, 11:49 AM   #10
blackedout010
Crowley
correct typo their you will be in 450-460 range with a cam. i was unclear wether he was asking 500hp or 500rwhp. however if u add heads and an lsxr intake you can hit 500rwhp mark.
Old 03-28-2009, 11:52 AM   #11
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
That's a bit optimistic for the LSXr intake. It gained 14hp at the CRANK on a stock LS3. I saw a post on ls1tech.com where someone with a built LS7 gained 21 rwhp. So for a typical bolton/cam LS3 you might see 10 rwhp (guessing).
If you're planning on 100hp over stock (Im assuming you're wanting 500hp at the crank), you're GOING to void your warranty. To do what would be required to make that much horsepower, you'll have to use something that will void it, be it a new cam, supercharger, intake manifold, etc.
Anyway, if you're shooting for 500 crank hp, mild cam, long tubes, CAI and tune should get you there.
If you're shooting for 500 rwhp, you'll need a supercharger (easiest, but mos expensive), or a slightly hotter cam, long tubes, CAI, and tune.
GMPP makes what they call the ASA HOT cam. It's the one used in the ASA racing series. Same lift as the standard HOT cam, but quite a bit more duration. And the GMPP cams are as cheap as any cam out there. Especially considering you don't have to change valve springs!
UsedTaHaveA68 is offline   Reply With Quote
Old 03-28-2009, 12:00 PM   #12
blackedout010
how do you figure supercharger is easiest??? not to be rude or come off bad have you ever owned a car with an sc?? ive had 2 and tons of headaches. from pulley combos to belt slippage both were constant headaches. with all the knowledge people have on ls based motors nowadays a good old heads and cam package is the way to go with least amount of hassle.
Old 03-28-2009, 12:03 PM   #13
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
It's a GM part and if installed by GM service people should be covered under warranty also as far as I know.
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 03-28-2009, 12:10 PM   #14
UsedTaHaveA68
I have not. I helped a buddy with a '97 Firebird Formula install his procharger a few years back, but no personal experience. But I did personally find it easier to install that supercharger than to install a new camshaft in that same car. He got rid of the S/C about a year after we put it in and went with a nitrous grind cam and a 175 shot of the giggly juice and a 3xxx stall converter. I know he had occasional issues with the S/C, but it wasn't his main decision to change over. And I don't know how much room is under the hood of the new Camaros, but changing cams in the old f-bodies were a bit of a pain.
I didn't mean to imply superchargers were the magic horsepower pill for everyone. That was the only one I've installed, and like I said I never had any personal experience of owning one. Didn't mean to come across as a know it all. I should have stated that between changing cams and installing a supercharger, the one that I've put in was much easier than the camshaft swap.
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
2010 Camaro Indy 500 Pacecar! roadie2991 Camaro Photos | Spyshots | Video | Media Gallery 129 05-24-2009 02:38 PM
