Cold Air Inductions
Old 09-03-2011, 05:03 PM   #1
rjsmith1973
rjsmith1973's Avatar
Drives: Aqua Blue 2SS/RS
"Clunk!" I know the problem, just not the solution
When stepping on the brakes at any pressure other than the most gentle, there is a loud "clunk" from the rear of the car, and a similar clunk when the pedal is released. With help, I was able to identify that the caliper assembly is moving and clunking against something, but I don't know what.
Suspension mods are Pedders Street Xa package and differential bushings with Pfadt trailing arms. I have been running fine on the setup for several weeks and then this noise started. Thanks for the help in advance.
rjsmith1973 is offline   Reply With Quote
Old 09-03-2011, 05:06 PM   #2
IROCanSS
Drives: 89 IROC 350
Um, caliper is moving? Not possible. Is it bolted inplace like it should be?
Old 09-03-2011, 05:12 PM   #3
rjsmith1973
Sorry, I'm sure my terminology is inaccurate. I think it could be described as the part that includes the pads/calipers and what they are mounted to. everything seems to be bolted in correctly, and everything was fine for several weeks after the install. I grant I could be mistaken, and if so, what else could cause that type of clunk?
Problem with rear end FIXED!!! Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 08-27-2011 10:47 AM
Somewhat Annoying Back Seat Problem! ZNOLMT 5th Gen Camaro SS LS LT General Discussions 5 06-21-2009 10:22 AM
Need your help to come up with a navigation solution for my new Camaro! Attorneyguy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 35 03-20-2009 05:59 PM
