Old 09-04-2011, 04:49 PM   #1
PercyJWellingtonIII
Drives: pontiac
Transmission failed!
Well it didnt totally fail but it willl not go in 1st gear. 1st gear position is locked out. All other gear postions are fine. V6 manual. Anyone familiar with this issue.
Its going in the shop Tue morn. Still under warranty. I hear other people complain that these foreign Aisin trans. are crap and don't hold up. Whats up with that? Why would GM sacrifice these cars with a junk trans. my car has just over 8k mi and has been perfect until now. Its a 2011.
PercyJWellingtonIII is offline   Reply With Quote
Old 09-04-2011, 04:51 PM   #2
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Sorry to hear about the tranny and hope GM does something about. Ford, Gm, Land rover all use Asian tranny's because it's cheaper. It sucks.
bajamoon is offline   Reply With Quote
Old 09-05-2011, 08:35 AM   #3
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
sounds like the pressure plate bolts went. Some people are having this issue, but most are only having the 2nd gear grind/bind issue.
Aries240SS is offline   Reply With Quote
Old 09-05-2011, 08:54 AM   #4
Hennesseyrgv
CAMARO5LINE FOUNDER
Hennesseyrgv's Avatar
Drives: Hennessey HPE650
My car, when I am about 6500 rpm and need to shift to 5th gear , it doesn't go in , when I am cruising in the city I don't have that problem , it does go in from 4th to 5th.
Hennesseyrgv is offline   Reply With Quote
Old 09-05-2011, 10:43 AM   #5
PercyJWellingtonIII
Drives: pontiac
All of the other gears are fine. Just wont go in first. Do you know any links on the net regarding this.
Old 09-05-2011, 12:35 PM   #6
SC2150
Bent shift fork......
Old 09-05-2011, 12:50 PM   #7
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Can you shift when the car is not running?
SamHouseIII is offline   Reply With Quote
Old 09-05-2011, 06:14 PM   #8
PercyJWellingtonIII
Drives: pontiac
No.
Old 09-05-2011, 06:19 PM   #9
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
Years ago I had a 4-speed get stuck in gear. I opened up the case (it had an access panel on top) and popped it out of gear with a screwdriver, and it's worked fine ever since. Maybe you'll get lucky when you get it apart.
2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen.
2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE
John Deere Boy is offline   Reply With Quote
Old 09-05-2011, 06:35 PM   #10
PercyJWellingtonIII
Drives: pontiac
Hope so, dropping it off tommorrow.
Old 09-05-2011, 08:24 PM   #11
Jcobra
Jcobra's Avatar
Drives: 2010 2ss/rs M6
My SS locked into neutral and it turned out to be the 1-2 synchros were broke. I have a thread on it in this section.
Jcobra is offline   Reply With Quote
Old 09-06-2011, 01:19 PM   #12
PercyJWellingtonIII
Drives: pontiac
Transmission Failed ...Update
Took it into the shop today. 1st gear was still locked out when he drove from the checkout line to the service bay...then...it became unstuck by itself! He took off the console and all was fine, checked for error codes...non found. Checked TSB's and non found in my vin# build. Fluid was fine. They contacted GM and they had no notice of this issue but GM told them to change the fluid anyway just to be sure. Sched. to go back next week so they can change the fluid because they didnt have it in stock. Drove it home and it performed flawlessly.
Bottom line...Reason unkown. Back in love with my Camaro.
Old 09-06-2011, 01:29 PM   #13
motorhead
Drives: POS MOPAR
I wouldn't be jumping for joy just yet. Problems don't just fix themselves.
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
