Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-05-2011, 03:23 AM   #1
Drives: pontiac
Aisin Ay6 Manual Problem-Old GM notice
Document ID# 2054933
Subject:Engineering Noise And Shifting Investigation In Aisin Rear Wheel Drive Manual Transmissions - keywords bearing grind growl intermittent rattle shift #PIP4270B - (01/29/2008)
Models:2007-2008 Cadillac CTS
2007-2008 Chevrolet Colorado
2007-2008 GMC Canyon
2007-2008 Hummer H3
2007-2008 Pontiac Solstice
2007-2008 Saturn Sky
Equipped with Aisin 5-speed Manual Transmission AR5 (RPO MA5) or 6-speed AY6 (RPO MV1, MV7)
This PI is being superseded to update contact information. Please discard PIP4270A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Engineering is investigating the above listed vehicles with the above listed manual transmissions.
  1. Leak concerns (i.e. input seal, output rear extension seal[mldr ])
  2. Noise concerns - Whine, Rattle or Growl
  3. Shift concerns - 4th gear, 5th gear or Shift lever issues
If your dealer receives one of the above listed vehicle in your dealer with one of the above listed concerns please contact engineering at the following number.
Reggie Callahan 734-417-0440
If engineering does not respond within 48 hours proceed with any necessary repairs.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
This is from 08 and they still stuck those ragedy transmissions in our cars.
Our Camaros have the Ay6 and the problems continue.
Call Reggie if you have an issue. Hope the Number is still good.
PercyJWellingtonIII is offline   Reply With Quote
Old 09-05-2011, 09:56 PM   #2
Drives: 2010 Camaro
Why I am not surprised?
piticu667 is offline   Reply With Quote
Clutch replacement costs? - Aisin Warner AY6 MT rolnslo Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 10 04-23-2014 06:08 AM
6-speed Manual Specifications (LS/LT) Tran Wiki 1 05-08-2011 09:33 AM
6-speed Manual Specifications (SS) Tran Wiki 0 10-19-2008 01:01 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 09:20 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 05:11 AM
