Gen5DIY
Old 09-05-2011, 02:44 PM   #1
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
Cranked my engine over by hand and the clutch made some noise?
During my header install I had the plugs out so I decided to crank the engine over by hand. In the same spot every time I cranked the motor over I hard a chattery sound from the bell housing for a brief second then it would stop. Is it normal for the clutch to make these noises? The car drives fine and the clutch works fine.
Some pressure plates have weights and such attached to them that can fall and make noise.
Or do I need the ZR1 clutch sooner than later. I had 1350 miles at the time.
I am assuming this was the clutch.
Pollock is offline   Reply With Quote
Old 09-05-2011, 04:41 PM   #2
Nessal
Drives: Exige, Miata, Ghia
I heard that there were issues with the pressure plate from factory that weren't torqued down correctly.
Nessal is offline   Reply With Quote
Old 09-08-2011, 07:47 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
sounds odd but i wouldnt worry about it if the area seems clean, excessive wear makes bell housing dusty, like brake dust on wheels.
Parag is offline   Reply With Quote
Old 09-09-2011, 01:31 AM   #4
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
I think every LS3 I've turned by hand makes that noise.
Then again, never hurts to have a ZR1 clutch
JDP Tech is offline   Reply With Quote
Old 09-09-2011, 02:17 PM   #5
Pollock
LT1 M6
Pollock's Avatar
I don't want to buy the clutch until I have to. Glad to hear I am not the only one.
