BORLA
Old 09-05-2011, 04:17 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
ADM Fuel Pump Solution
ADM Performance is proud to announce a fuel pump solution for those that dont want a boostapump.
If you own a:
Whipple,Magnacharger,Vortech,Edelbrock,Kennebell,T urbo,Nitrous,E-85 fit
2010-2012 Camaro that requires more fuel than the stock fuel pump can handle,we have the answer.
After extensive testing on the Street,on the Dyno and on a Flow bench the results came back positive.
On a Lingenfelter Built Low Compression 376 Auto,Magnusun TVS2300Overdriven cog rear,3.6 front pulley car with 3:45 gears we made 601 rwhp and 582 rwtq on 93 octane fuel with room to grow.
Using 85lb injectors and this fuel pump at 58psi rail pressure we showed virtually no pressure drop from 2500rpm-6900rpm,the injectors were just at 61 percent duty cycle at 6800 rpm.Not bad considering the pump module uses the same FPCM,Fuel level sensor,same connector and requires no wires to cut and is 100% made for E-85 as well as Gasoline.These pumps are designed for variable speed as well as fixed speed,they are not gear pumps.
(We have not tested this pump to 20volts,Current test was at 14 volts)
We will let you be the judge:
Stock pump is on the right
Stock pump body diameter
ADM HP Pump/ZL1 diameter
Stock Inlet
ADM HP Pump/ZL1 Inlet
RPM hp ft-lbs FUEL
3.40 369.20 570.36 58.72
3.50 379.69 569.74 58.40
3.60 392.86 573.13 58.33
3.70 403.80 573.22 58.41
3.80 415.99 574.93 58.45
3.90 428.55 577.13 58.42
4.00 438.31 575.53 58.37
4.10 450.23 576.73 58.28
4.20 462.99 578.97 58.13
4.30 474.96 580.12 58.00
4.40 487.97 582.47 58.00
4.50 498.27 581.56 58.11
4.60 505.60 577.29 58.21
4.70 515.39 575.93 58.18
4.80 526.04 575.60 58.09
4.90 534.09 572.47 58.00
5.00 544.02 571.45 57.88
5.10 550.36 566.80 57.78
5.20 558.42 564.00 57.97
5.30 564.81 559.74 58.38
5.40 569.45 553.86 58.63
5.50 573.91 548.05 58.04
5.60 579.85 543.83 57.48
5.70 583.43 537.60 57.87
5.80 589.30 533.63 59.08
5.90 596.86 531.33 59.70
6.00 600.09 525.29 59.43
6.10 599.98 516.60 58.98
6.20 600.85 508.99 58.29
6.30 601.60 501.55 57.69
6.40 600.37 492.70 57.66
6.50 601.50 486.03 57.86
6.60 600.54 477.89 57.92
6.70 599.18 469.69 57.86
6.80 599.21 462.80 57.35
ADM PERFORMANCE is offline   Reply With Quote
Old 09-05-2011, 04:20 PM   #2
ADM PERFORMANCE
We have plenty of inventory and can ship same day.
Dealer Inquiries welcome.
Please email for pricing - admperformance@gmail.com
Old 09-05-2011, 04:47 PM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
I will be needing this when I get my 416 !!!
Camaro21 is offline   Reply With Quote
Old 09-05-2011, 05:04 PM   #4
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
I NEED IT NOW!
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 09-05-2011, 05:15 PM   #5
BlownChevy
Drives: 2015 1SS RS 1LE
Great Product! We are proud to carry ADM Fuel Pumps!
BlownChevy is offline   Reply With Quote
Old 09-05-2011, 06:16 PM   #6
Synner
Drives: not stock
What are the power limits of the new pump? At what point would a BAP or your other fuel pump be required?
Old 09-05-2011, 06:51 PM   #7
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Your measurements show close to a 25% increase in the inlet size and I assume the overall pump diameter is needed to drive the added inlet volume. And it is not gear driven. Like some of the questions posted here I wonder as well what it will do with a boost a pump on 20V? What is nice is if you install the ADM pump with an early build and later on go wilder then it is easy to wire in the BAP to go to a higher level and all this using factory Camoro Fuel Pump Control Module. AND, I am on E85. Win/Win
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 09-05-2011, 06:54 PM   #8
LittleMT
user bann'd
LittleMT's Avatar
Drives: Chevy SS
Kindly set one aside for my Chantilly Lace............
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6.
LittleMT is offline   Reply With Quote
Old 09-05-2011, 07:15 PM   #9
ADM PERFORMANCE
Our basic dual pump system is good to 750rwhp or 900flywheel.
At 14.8 volts supports 850 to 1000 hp depending on engine efficiency.
At 20.0 volts supports over 1000 hp depending on engine efficiency.
"NEW ADM HP"
At 13.5 volts supports 675 to 700 hp depending on engine efficiency (BSFC).
At 14.8 volts supports 700 to 800 hp depending on engine efficiency.
Old 09-05-2011, 10:04 PM   #10
Synner
Drives: not stock
Cool. So it could handle a stock pulley whipple, bolt-ons, and cam in the 630ish hp range and you don't need to rip your interior out or mess with wiring for the install.
Old 09-06-2011, 07:13 AM   #11
ADM PERFORMANCE
Your application is why we have this pump.
Old 09-06-2011, 09:26 AM   #12
2SS\RS
Drives: 2010 Camaro 2ss/rs
Can you pm me a price? 89148. thanks!
2SS\RS is offline   Reply With Quote
Old 09-06-2011, 03:18 PM   #13
ADM PERFORMANCE
PM Sent
Old 09-06-2011, 06:41 PM   #14
CyberPredator
50 Shades of Prey
Drives: TT/SS
So is higher voltage like 20 working the pump to hard??
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
WTB: LPE or ADM Twin Fuel Pump db1918 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 08-31-2013 04:17 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Camaro Fuel Pump Solution ProudLS Forced Induction - V8 30 04-02-2010 02:14 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
