HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 09-05-2011, 07:11 PM   #1
montreal2010yellow
montreal2010yellow's Avatar
Garage Door Spring Broke.
Tonite I hopened my garage door with the electric opener. Suddenly, BANG the left side spring just broke and it went wild bending some elements like the end bracket that holds the spring on the ceiling. Lucky enough I did install a safety cable, as it was recommended by an inspector when I bought my house 5 years ago.
I'm glad I did it, I now know how much strain there is on the spring when the door is opened. You can't imagine... If it would'nt have been secured I'm sure it would have done quite a lot of damages, or even hit me HARD.
So for those who don't have a safety cable running inside the spring, please do it ASAP. Thrust me, the spring really goes WILD.
Here's a pic of the bracket. Note that the hook was facing the door before it go hit by the spring assembly, and now it is bended 90 degree left!!!
Name:  garage door bracket.jpg
Old 09-09-2011, 01:52 PM   #2
montreal2010yellow
Update
Door fixed 263,00$ after.
For those who don't have a security metal wire going through the big spring, do it ASAP, you can't imagne the damages that this wild spring can do. Luckily my car was'nt in the garage. The wire detached after the spring broke and it would have done a lot of damages to the car, and even me because I was right behing the bracket that go hit.
Case now closed.
Old 12-07-2012, 03:58 AM   #3
sandrawill
Drives: M3
Malfunctioning garage door can be quite dangerous, as a common action by owners is to activate the quick release mechanism in order to operate the door manually.
sandrawill is offline   Reply With Quote
Old 01-23-2013, 08:53 PM   #4
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
One busted on my door once luckily it didn't hit me or my 57. When I replaced it I too added the safety cable. Good advice. To all.
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 01-23-2013, 08:56 PM   #5
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Great advice. Guess I better go get some cable.
Old 01-23-2013, 09:00 PM   #6
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
I have a 2 car garage with 2 doors.. Same thing happend to me...good thing for the safety wire.... Dirty, greasy job to fix it... But it's simple.... I replaced 3 of mine so far..
kevin1106 is offline   Reply With Quote
Old 01-24-2013, 08:39 AM   #7
spike III
COTW 6/25/12
spike III's Avatar
Good to see this.I've been wondering if anyone else had this happen. Last summer I hit the garage door opener I was in the garge. The spring didn't brake for about 10 seconds. I turned too go to the back of the garage heard a big noise and ducked. When the spring broke it just grazed the side of my head. Went between the car &wall over the top of my head. That day was probably the luckiest day of my life & somebody was defnitely looking over me. Door didn't have safety cables,but has new springs & safety cables.
spike III is offline   Reply With Quote
Old 01-24-2013, 11:46 AM   #8
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Had the same thing happen years ago, spring broke and took out the fender to our old Ford. After that the safety cables got put in, then switched to the new style garage door spring with the new for a few years ago.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 01-24-2013, 11:55 AM   #9
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Those springs can be dangerous. They have a lot of tension and if you are not careful when adjusting them they will seriously do some damage to you. I have heard some bad stories from when there was a garage door repair man out at my house to fix a loose spring.
Proud owner of litho #179 Click Picture for Build Thread
Old 01-24-2013, 02:48 PM   #10
Stealth 2010 2SS/RS
Oh yes they can, i could of put the new door and spring in but had a friend of the family that does home remodeling do it.
2010 LS3 2SS/RS M6
Old 01-24-2013, 08:20 PM   #11
camaro2lt
camaro2lt's Avatar
anyone have a pic of this saftey cable?
Old 01-25-2013, 01:27 PM   #12
Stex
Drives: 67 goat, 69 goat ram air III
http://www.checkthishouse.com/656/ga...-and-more.html
Stex is offline   Reply With Quote
Old 02-07-2013, 02:26 PM   #13
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Yeah, I've had several break... its scary but the cable keeps it from causing any damage.
Really simple to replace, I just pick up a pair from Home Depot (just match the color codes) and always replace in pairs. The only trick is to *not* remove all springs before starting installation - you need to follow the cable routing from the 2nd spring while replacing the first.
Old 02-07-2013, 10:12 PM   #14
Ocx
Ocx's Avatar
Drives: 2013 Camaro 2SS/RS
Originally Posted by clg_98ta View Post
always replace in pairs..
This.
Ocx is offline   Reply With Quote
Looking for cool banners for my garage the rich dude Garage / Tools Discussions 15 06-02-2014 06:33 AM
New House w/ 3 car garage 01pewterz28 Garage / Tools Discussions 34 08-11-2011 09:41 AM
$300 worth of grocceries and cleaned out my garage fer the Vert. SUX2BU Camaro Photos | Spyshots | Video | Media Gallery 15 03-24-2011 12:01 AM
broke my side mirror backing up from my garage :( ucfq8 5th Gen Camaro SS LS LT General Discussions 23 03-09-2011 06:27 AM
garage? Mrbobcat Off-topic Discussions 5 05-07-2008 08:46 PM
