SDTW Custom Wheels & Tires
Old 09-05-2011, 11:48 PM   #1
DarkAceXXX
Drives: 2011 Camaro 2SS/RS, 2006 Cobalt SS
Question New to the camaro little confused
I bought me a new 2011 camaro ss/rs and i was just wanted to know why does my clutch make a noise when i press it when im about to park? i can't find my owners book to look it up.
Thanks
DarkAceXXX is offline   Reply With Quote
Old 09-05-2011, 11:52 PM   #2
reedster20
Drives: 2010 Camaro 2SS/RS LS3
what kind of noise and what area does the noise come from?
reedster20 is offline   Reply With Quote
Old 09-06-2011, 12:00 AM   #3
DarkAceXXX
it sounds like a gear noise only when im about to park up hill i normaly put it in Neutral just before i stop. just when i press it almost at a dead stop. some people say i have to press the brake at the same time i do the clutch is that right?
Old 09-06-2011, 12:54 AM   #4
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
No.
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 09-06-2011, 01:07 AM   #5
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Your description still does not have enough information. What kind of gear noise? Grinding? Popping? Winding? Rattle? How often does it occur? How can we help if you barely give us information?
Regardless.....if you think there is something wrong, bring it to the dealer for possible warranty work.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 09-06-2011, 02:28 AM   #6
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Mine does this also. However, I found it only did it when I pressed the clutch in before the RPMs had gone down enough. It never has this issue at speed, thankfully.
Powhusku is offline   Reply With Quote
Old 09-06-2011, 06:01 AM   #7
10forty2
10forty2's Avatar
Drives: 1992 Chevy K5 Blazer
There shouldn't be a noise when you press the clutch pedal in, regardless of what speed you are running when you press it. All that does is separate the the engine from the transmission. If there's a noise, then there may be something wrong that needs to be checked by your dealer.
Love beautiful photos? Please visit:
http://dougloganphotography.zenfolio.com
10forty2 is offline   Reply With Quote
Old 09-06-2011, 11:32 AM   #8
DarkAceXXX
I can't really explain how it sounds when it happens. All i know is that it does disengage but it makes a noise im gonna take it in to the dealer friday cuz i don't like the way is sounds. Has anyone ever had the same problem with there camaro? I have never had this happen before.
Does anyone who if this should be cover under warranty I don't wanna pay any deductible if possible i only had it for a week.
Old 09-06-2011, 11:43 AM   #9
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Does it sound like when you add another plate to a weight bench bar? Like a rattle of two metal plates hitting each other?
Old 09-06-2011, 01:48 PM   #10
DarkAceXXX
Did you ever find the problem? Or did it just go away i bought the car new so I don't know cuz its still New or its something else. So far the car has 1100 miles im thinking maybe because its new but this is my first new car. Thanks
Old 09-06-2011, 08:05 PM   #11
Bogey99
Bogey99's Avatar
Drives: 2010 2SS/RS Black
I get the noise when going slow at low RPM and the clutch is pushed in. Its a clunky shutter sound.
Bogey99 is offline   Reply With Quote
Old 09-06-2011, 08:31 PM   #12
techinny
techinny's Avatar
Drives: '12 Silverado 1500, '05 GMC 2500HD
Is this the first standard transmission you have had? From what I get out of your descriptions, I am guessing the engine is about to stall when you push the clutch in, (meaning you are waiting too long to push the clutch in), and the noise is the pressure that is on the drive line releasing and making the drive shaft "bounce". If this is the case, it is operator inflicted and nothing wrong with the car.
On a side note, you have only had the car a week, and you already have 1100 miles on it, you don't let it cool off much do you?
Had: 2010 SS/RS M6 Hurst STS, Noweeds
techinny is offline   Reply With Quote
Old 09-06-2011, 10:21 PM   #13
Bogey99
Bogey99's Avatar
That sounds exactly right.
Old 09-07-2011, 06:13 PM   #14
DarkAceXXX
Yeah I need it to rest but its a fun car to drive. I slowed down driving it. I noticed if I push the clutch slow it doesn't make the noise. I think everything is ok
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
