B&M Racing
Old 09-06-2011, 05:20 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Shifter difference.
ok so me and my friend both have hurst shifters same part number shifter and all. He has a SS2 and i have the V6. His is alot tighter feeling and has a shorter throw. So im wondering what the differnences are in the shifters? Can i put the the shifter outta the SS in my car? Like the linkage and the brackets?
2010_camaro is offline   Reply With Quote
Old 09-06-2011, 05:21 PM   #2
2010SS2SS
2010SS2SS's Avatar
Drives: 2010 Camaro SS 2SS
more than likely different gear ratios in the two transmissions...
2010SS2SS is offline   Reply With Quote
Old 09-06-2011, 05:34 PM   #3
2010_camaro
well its not that. its just the feel of the shifter when you change gears. its alot closer gear shifts and tighter feeling
Old 09-06-2011, 06:19 PM   #4
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
From your description, the lower bushings on your Hurst shifter may have been damaged during install. Shifts should be precise (tight) and short without much free-play or slop while in gear (much like what you have described in your friends car). Contact Hurst at (818)483-1366 for new lower bushings.
You won't need to completely remove the shifter to install the lower bushings... and be careful when installing the cross pin into the new bushings. Do not force it in - it should be a slip fit.
BTW- the TR-6060 transmission in the SS does have a slightly shorter gear engagement (roughly 5mm) than the AY6 in the V6.
Kenji is offline   Reply With Quote
Old 09-06-2011, 06:25 PM   #5
2010_camaro
well the pin went in fine. I wonder if they make metal bushings for the shifter other than the teflon ones. I like the sound of a loud shifter.
Old 09-06-2011, 06:38 PM   #6
Kenji
Kenji's Avatar
Most people don't (even on purely race cars). Plus, unless a coated or oil impregnated metal was used for the bushings and a new hardened cross pin (the stock one isn't hardened) was used you would still have to constantly re-lubricate. This is one of the many reasons Hurst used Teflon in this area.
A better option for someone who wants more noise would be a harder high temp polymer (possibly 20-30% glass filled) with a minimum of 10% PTFE (Teflon) for smooth operation.
Old 09-06-2011, 07:43 PM   #7
pnyklr
Drives: A Gift From My Wife
What the hell do you do for a living?
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 09-06-2011, 08:06 PM   #8
2010_camaro
ok i have a video of my shifter play. how do i post it on here?
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
Attention V6 Owners--Trade in your Factory Shifter for the MTI Shifter MTI Racing Kevin Transmission / Driveline 15 06-21-2011 04:09 PM
V8 and V6 Shifters in stock for your 5th Gen MTI Racing Kevin Transmission / Driveline 0 02-08-2011 05:12 PM
- Sale on The Best Camaro Short Shifter - Sale Ends Monday or While Supplies Last - MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 11-09-2010 03:24 AM
- Sale on The Best Camaro Short Shifter - Sale Ends Monday or While Supplies Last - MTI Racing Transmission / Driveline 0 11-05-2010 08:07 AM
