Gen5DIY
Old 09-06-2011, 06:43 PM   #1
Sketch
Sketch's Avatar
Drives: 2011 Camaro 2SS RS RJT
Lightbulb Gas Milage Build?
When modding a car, its usually done for power/looks. Has anyone tried doing a build on the v6 to squeeze as much gas mileage out of it as possible? If done right, this can prove how worthless so called "green" vehicles are. Any suggestions?
Sketch is offline   Reply With Quote
Old 09-06-2011, 07:34 PM   #2
aet08
Drives: c
WHY?
aet08 is offline   Reply With Quote
Old 09-06-2011, 07:53 PM   #3
hypnatic
hypnatic's Avatar
Drives: Victory Redhead
imo these cars get great gas mileage considering the horse power... if your not buying aftermarket for power than buy for weight reduction, this should give you better gas mileage
hypnatic is offline   Reply With Quote
Old 09-06-2011, 07:55 PM   #4
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
I recently got 29 mpg coming back from DC and I have 420 rwhp. I think that is amazing gas mileage.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 09-06-2011, 08:08 PM   #5
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
Originally Posted by aet08 View Post
WHY?
+1.
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein
tsears is offline   Reply With Quote
Old 09-06-2011, 08:57 PM   #6
Sketch
Sketch's Avatar
WHY?
I would assume that with a cold air intake, headers, and lighter cat-back exhaust, I would gain both power and gas mileage. As for why I would want a fast car thats good on gas and breaks necks? Bragging rights? I also use my Camaro as a daily driver. With gas prices rising, this build sounds better and better.
Old 09-06-2011, 09:29 PM   #7
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I suppose if you added full bolt ons onto a V6 car and had someone like Vince at Trifecta work you up a conservative fuel saving tune it could be done.
Your number one stop should be your driving habits and wheel/tire set up. The stock rims are heavy as well as the entire exhaust system.
DarkneSS is offline   Reply With Quote
Old 09-07-2011, 02:48 AM   #8
C586
Drives: 2011 Camaro LS
I get 23 mpgs around town and have hit 33mpg trip average on the highway. Rotofab CAI and MRT 2.0 is all I have done. Turbocharging a small engine is the way to get fuel economy. My supra averaged 27 mpgs on the highway and I was making over 700 rwhp.
C586 is offline   Reply With Quote
Old 09-07-2011, 04:24 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Yes but that dropped to 5 mpg when boost was over 15psi.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-08-2011, 09:47 AM   #10
C586
Ok. But I usually stayed out of boost. It was a daily driver. And I played around for a little bit and it did get down to 6.2 mpgs. Lol. But generally I could average pretty good mpgs with such a crazy amount of power.
Old 09-10-2011, 01:03 PM   #11
TooCool5
TooCool5's Avatar
There's a guy on here that installed a dual cone CAI, and had flowmasters on his V6 was getting 38 MPG.
Wish I could find the post.
Old 09-10-2011, 07:29 PM   #12
Sketch
Sketch's Avatar
I found the post. I think his computer was mis calculating the MPG. The best way to get fuel efficiency from air is to use cold air since colder air has more oxygen than hot air. His intakes are not shielded so it is sucking in hot air from the engine compartment. I think the best intake for my build would be a varram Intake or a Injen.
build, green, mpg, v6 gas milage
gas milage question. porankazi 5th Gen Camaro SS LS LT General Discussions 35 02-03-2011 11:47 AM
Bad gas! Camaro sputtered & died gzartman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 09-07-2010 06:45 PM
using higher octane on v6 need4spd 5th Gen Camaro SS LS LT General Discussions 66 06-02-2010 03:24 PM
Detroit Autos Insider: Milage at the top of new cars buyers lists Scotsman General Automotive + Other Cars Discussion 2 03-24-2008 06:29 PM
Gas Guzzler Tax Roflmao Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 02-29-2008 06:29 PM
