Emblempros
Old 09-06-2011, 07:00 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
1st to 2nd is slow
ok. I had the normal tranny 1-2 grind but i got all that fixed. Even before i had the tranny worked on going from first to second at high RPMs it seems to shift slow. like it gets caught between gears or a fraction of a sec and then it goes in gear. The tranny dont grind and shifts fine any other time. its just when i try and speed shift from 1st to 2nd. now going from 2nd into 3rd it dont pause at all. I do have a hurst shifter. is that just the nature of the tranny?
2010_camaro is offline   Reply With Quote
Old 09-06-2011, 07:08 PM   #2
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
From what I understand, yes it is the nature of that tranny. Others on here would just call it junk. I'm not so sure they are wrong.
Old 09-06-2011, 07:42 PM   #3
2010_camaro
GM needs to step up there game on making a sports car.
Old 09-06-2011, 07:44 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
Well, for the money, I think they did a damn good job with both the 6 and 8. Yeah, they need to tweak some things, but overall, just a kickass car.
Old 09-06-2011, 08:48 PM   #5
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Trannys garbo for a sports car. If it was an economy car then sure, it shouldnt have to take highly aggressive shifts.
Seems like the V6 tranny isnt strong enough for the power the LLT puts out. Combine that with weak parts and you get a bad tranny. Seems like the V8 tranny can handle the stock power fine but it also has the part quality issue.
DarkneSS is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
2nd to 1st in Sport Mode JChen Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 40 09-29-2011 07:38 PM
M6 V8 Owners - Start Off in 1st or 2nd Gear? LT4Lover 5th Gen Camaro SS LS LT General Discussions 40 08-17-2011 04:45 PM
1st and 2nd gear whistle or whine? bmorecam Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 05-07-2011 01:05 AM
AY6 1st to 2nd Grind c_LoW29 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 25 01-31-2011 09:25 PM
