JDP Motorsports
Old 11-03-2011, 09:29 PM   #127
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Originally Posted by mikepage0007 View Post
i believe they are same ones i have...one problem i had was after about 200 miles , i started to get a tapping noise...finally ripped down pass side and removed them and installed oem and motor was quiet...for 200 miles..meanwhile could not see anything happening when they were on car...clearance was so close to head..could not see any marks with the naked eye, using a magnifying glass , i found 2-3 that had microscopic marks that were different then the rest,,,deciding to polish all of them in this location , and removed very small edge area with emory cloth..reinstalled 2000 miles ago and noise has never returned...the hit spot was at top area of head where rocker dipped in towards intake...just thought i would throw that out there...in case you come across it down the road
The rockers? They are ls7 rockers, I doubt it. YT6670 ultralights
Got a tracking number for the heads and rest of the engine stuff. Lots of updates and new pictures coming next week
DietCoke is offline   Reply With Quote
Old 11-07-2011, 03:34 PM   #128
full of days
full of days's Avatar
Drives: Camaro GT
This is the world's greatest hotrod thread. That is all...
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 11-07-2011, 07:04 PM   #129
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
correct, these yella terra are on my ls3 right now..i have stock ls7 rockers..
mikepage0007 is offline   Reply With Quote
Old 11-08-2011, 01:08 AM   #130
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Scored a DEAL on a Beck intake... one time opportunity I couldn't pass up. Super excited to have such a nice piece to top off the engine.
Old 11-08-2011, 08:31 AM   #131
full of days
Drives: Camaro GT
D.Coke - I know you mention that you avoid tracking cost, but it would be interesting to see what the grand total of parts alone will be in the car.
One more question - With the 429, Jake's 4L80e, etc are you expecting to freshen up the top end often? Are you anticipating any weak links in the car? (i.e. having to chase down parts that break?) I assume that's normal routine for a 10 second drag car... ? Maybe not...
Post Tenebras Lux
Old 11-08-2011, 09:28 AM   #132
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
You beat me to that intake by like an hour!
It was a screaming deal.
HufferSS is offline   Reply With Quote
Old 11-08-2011, 12:27 PM   #133
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
Hey Chris what are you doing about the Driveshaft?
Version I
Jannetty Racing 550 RWHP Street Brawler Package,
Powered by TVS2300 Maggie
http://www.camaro5.com/forums/showthread.php?t=100385
Version II
416ci stroker/4L80e
701rwhp 750rwtq
build and tuned by
SPI-Performance
69 Rebel is offline   Reply With Quote
Old 11-08-2011, 09:27 PM   #134
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
The motor shouldn't need regular freshening, it wont be turning stupid rpms, has a moderate camshaft lobe, and moderate valve spring pressures. I'll run it into the ground, unless the rings get weak. I doubt I'll put 2000mi/yr on the car.
@69 Rebel, I will have one made once I get the transmission in and measured for length.
Old 11-08-2011, 11:21 PM   #135
mikepage0007
Drives: 2010 camaro
i,ll be waiting for that measurement..lol..
Old 11-10-2011, 09:06 PM   #136
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
It's all here, assembly pics to come. BEHOLD! The first production set of TSP Small bore LS7 heads! Sheet metal intake comes tues. Assembly pictures to come.
Old 11-10-2011, 10:26 PM   #137
andredmg
Big Nasty
andredmg's Avatar
Drives: Chevys lots of em
Those heads are extra sexy!!!:thumbsup :
andredmg is offline   Reply With Quote
Old 11-11-2011, 03:28 AM   #138
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Plum tired out. Will get back on it tomorrow. Got a good bit done. Need to get a burr and a die grinder to clearance the front cover for the double roller tomorrow. Slightly touches in a couple spots. Got one head on and called it for the night.
It was cold in the garage, so I wheeled the engine into the foyer. Sophistication at its finest.
First task complete: Install crank key, tap on crank sprocket and oil pump drive, seat oil pump and install pickup without tearing the O-ring. Done.
Love that rollmaster double roller.
Oil pan gasket installed, oil pan bolts torqued, engine flipped right side up.
Next task, install donkey dick camshaft with copious amounts of assembly lube and break in oil. Check.
Install cam retainer with fresh bolts with loctite. Check
Install cam sprocket. Check. You can install this before the oil pump if you choose. I didnt. Installed at 0 degrees advance, 3 degrees ground into the cam. 113LSA+110ICL
Timing chain complete
One bank of lifters + trays installed
Head set down, ARP studs torqued with ARP assembly lube
One bank finished... more to follow
Old 11-11-2011, 07:11 AM   #139
mikepage0007
Drives: 2010 camaro
you made it obvious now, your def not married ..you now have more engine parts in the kitchen then in the garage...lol..good looking motor
Old 11-11-2011, 07:30 AM   #140
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Lol....definitely not married.
Me and a buddy joke about the old days and a car I used to have...we built a 406 small block for it on my coffee table.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8802 Yesterday 10:30 AM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
